Question about IBM ThinkPad T43 Notebook
"Power Surge on Hub Port
I repeatedly get the message "Power Surge on Hub Port: A USB device has malfunctioned and exceeded the power limits of its hub port. You should disconnect the device." This is despite the fact that no device is plugged in. It doesn't seem to affect the functionality of the computer as far as I can tell but it is still concerning. Any advice on how to address this?
  • bebexsmiles Mar 10, 2009
    i plugged my ipod usb in and the power surge hub port did popped up so i disconnected my usb. now i cant charge my ipod or change songs ;( only my ipod usb doesnt work, other usb works.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
That series of laptop has a problem with it's battery which causes malfunction...
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=BATT-LENOVO
Moreover, make sure you have current BIOS and driver updates for you laptop, not all manufactures offer complete firmware updates like Lenovo; take advantage of it.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58597
Posted on Nov 27, 2008
A USB device has exceeded the power limits of its hub port
Windows display this message when a USB device is short-circuited. Try another USB cord or connect the usb to the port at the back of your pc. If it does not help then the problem resides in the printer. I will not suggest to dismantle your printer as there are no user serviceable parts inside.
Aug 10, 2009 | Canon LaserBase MF5650 All-In-One Printer
Power Surge error message
can you please detail the exact name and model of your hub..?
Thank you
May 13, 2008 | HP Pavilion dv4000 Notebook
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge on hub port message
Use a powered hub, one that has it's own power supply.
May 09, 2009 | Microsoft Windows XP Home Edition
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge message
Problem :Overvoltage on USB hub port
Solution: Look carefully at that same port and you will four gold pins make sure they are NOT touching each other..
Apr 16, 2009 | Computers & Internet
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Try this to find out which one of your components has an issue. Turn off your machine then unplug all of your USB cables. Turn your machine back on and plug in one of your USB cables. Verify the component you just plugged in works correctly and if it does plug in another cable and verify that component is working. Continue these steps until you have the one component that displays the error you have seen. That component is most likely the cause of your issue and should be replaced.
Good luck, Greased.
Jan 28, 2009 | Dell Dimension 4700C PC Desktop
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
949 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
