Question about HP Office Equipment & Supplies
Hourglass symbol in middle of screen don't know why
  • Curtis Richner May 11, 2010
    Why is this assumed to be a printer issue? The mouse hourglass icon indicates an application is performing a task. More details are required for diagnosis. When does it appear, etc.?
I too have this problem and I have found how to correct it. It worked for me and hopfully it will work for you and others. Turn off your printer. Open the scanner cover. Turn your computer back on. That is what I did and it fixed it for me for now. Please send me an E-Mail if it fixed it for you. I have a sneaky suspecion that it just started working again and me opening the scanner cover was not the fix. Thanks, Wayne
Posted on Nov 08, 2010
  • taffertap Nov 08, 2010
What does The Hourglass symbol mean on a Samsung front load washer
The hourglass symbol usually means the machine is "Delayed" This might be because of a breakage or issue inside the machine. If this is not the case, check the user instruction manual
Oct 03, 2016 | Samsung Washing Machines
I have a brighten symbol that keeps popping and I can't get it to go away right in the middle of screen
go to set up menu then select the brightness adjustment and then exit.if can get with adjustment turn off then unplugged don't use for an hour to reset the power supply.
Aug 12, 2012 | Mag Innovision LT776s 17" LCD Monitor
Picture has hourglass look and has split screen picture hourglass comes and goes but split screen is continual
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Apr 06, 2012 | ESA EF427E TV
I plugged in into my computer and just has an hourglass symbol on it
hi, an hourglass symbol indicates that it is loading or your computer is trying to access the unit. Hope this helps. goodluck
Jun 23, 2010 | Audio Players & Recorders
There is a small symbol of headphones in middle of screen
That symbol is the MUTE, you need to find out how to remove the Mute. Have a look in your manual. Download link below.
nds1.nokia.com/phones/files/guides/Nokia_5140i_UG_en.pdf
Apr 12, 2010 | Nokia 5140i Cellular Phone
Frozen hourglass symbol on mp4 screen
If you are using Mac, you must use USB to connect to connect to itunes. If you are using Windows you MUST use Firewire. I don't know why this is but each system won't recognize the other's connection medium. Make sure you are using the correct cable. If my wire connection doesn't work then it is reversed. Try it the other way around. The only other thing I could think of is that you are trying to upload an MP4 that the system doesn't recognize. try a format converter if this is the problem, they can either be demoed or bought four 20 bucks or so.
Mar 21, 2009 | Apple iPod touch
Constant hourglass symbol-draining battery
Hi, this is called the hourglass of death, the device is stuck in a reboot cycle.
You will need to reload the applications, but you can't use Desktop manager because the device resets and the connection drops.
First make sure the BB is unplugged, then go to Program Files > Common Files >Research In Motion > AppLoader and run loader.exe. Click next, it will say port : COM PORT 1 now is the tricky part you have to plug in the BB and COM 1 will change to PIN: UNKOWN , when this happens you have to quickly click next before it reboots again, then it will ask for pin and now has an connection with the device so you can go ahead and re load all the apps.
Good Luck
Apr 16, 2008 | RIM BlackBerry 7250
Hourglass symbol
dear lund0448
there might be some hardware problem or may be obstruction in the way of the print cartridge carrier.better check it yourself by opening the printer or you send it for servicing.
Feb 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
95 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
