Question about Mpio FY500 MP3 Player
MP3 Player Won't Turn On
My mp3 player ran out of batteries, and I turned it back on but it faded out and turned off while it was loading. Now it won't turn on after I replaced the batteries, and I checked that the batteries worked, and they did. How can I fix this and make it work again?
Im having the same problem
Posted on Sep 14, 2008
Frozen on o2 screen. wont turn on/off.
Hi Sam, The link below is a YouTube page full of videos showing how to turn on your mp3 player and unfreeze it.........CHEERS..
https://www.youtube.com/results?search_query=how+to+fix+a+mp3+player+that+won%27t+turn+on
how to fix mp3 player that won turn on YouTube
Apr 29, 2016 | Audio Players & Recorders
My Philips GoGear MP3 won't turn on. Is there any way it can get fixed? I've tried resetting it but nothing happens.
(I "ASSUME" you charged it, or tried to). HOW OLD is your MP3 player??
If it's pushing 2yrs old, or played/used on a fairly regular/daily basis,
.....YOU MAY JUST NEED A NEW BATTERY.
Carefully peel up the UPC code strip on back of player. (There is a tiny screw underneath it)
Carefully remove screw. (The snap notches are 'L' shaped inside the edges of the case).
Gently slide/pry open the backside of the case, taking care NOT to break the snap notches.
Open case, REMOVE BATTERY. FIND/MATCH BATTERY TYPE. (look in WATCH batteries).
Place the new battery in player. Close case, restart/turn on player.
Nov 04, 2011 | Philips GOGEAR SA6045 MP3 Player
I ahve a no name mpe player and try to sart it and it just comes up with the loading symbol but will not go any further
Hi there
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
Sep 16, 2010 | Jwin MP3 Player
My mp3 player won't turn on anymore.
The battery is Dead mate, Rechargeables only have a certen amount of time they can be recharged
Sep 27, 2009 | Nextar MA933A MP3 Player
My rca th1100 want come on!
will not come on what can i do ?
Nov 13, 2008 | RCA TH1101 MP3 Player
Digital media player
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Aug 12, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Screen fades out whenever i choose a song
Software corrupt. Try finding out how to install it again or update firmware. If you cant, get another brand. THey like cheap, stop trying to ressurect the dead
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
Sansa MP3 Player will not turn on
I had the exact same problem it was after I ran a new firmware update, it flashed on and then turned off and would not turn on or recognize the computer. Solution: Since i didn't have a mini screwdriver to take the battery out, I held down the menu and power button for 15 seconds let go and it powered right up and works great.
Nov 03, 2006 | SanDisk Sansa e250 MP3 Player
Mpio FY500 MP3 Player Logo
117 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
