Question about Acer Aspire 1642WLMi Notebook
Acer Arspire 1642 WLMI does the vga output support tv out?
Hi - Trying to connect notebook to tv for watching video files
want to connect to plasma tv and at times also standard tv via s-vid
input. Thank you for your time, greatly appreciated Acer Arspire 1642 WLMI 1.73 GHz
  • 4 more comments
  • ktwil Nov 27, 2008
    Have looked in laptop manual and online but can't find out if it
    has TV out or S Video out facility built in?
    Thank you again for your time.
    Thank you.
    How do I check if the VGA output on the laptop has TV out facility?
    Thank you so much you were great help!
    Will now go and buy the correct cable's thanks to you :-)
  • Anonymous Feb 07, 2009
    hi i try to connect note book to tv i have vga cable to s videi cable,but i coundn't get connection
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    the S video on the laptop should look something like this:it should be in the side or back
  • Lalit Varadpande
    does the TV have VGA input?u can use a VGA cable to connect to the TV if it does..for regular TV u will have to S video to three RCA cable..do check if the laptop has S video or TV out..
  • 488 Answers
I dont think it has..you can then buy a VGA to RCA for the regulatr TV(should work for both the TVs)
an example is here
http://www.cablesnmor.com/vga-rca-cable.html
please info if u want more help,will be glad..regards
Posted on Nov 27, 2008
  • Lalit Varadpande
    Lalit Varadpande Nov 27, 2008
    you dont have to..all you need is to connect with the cables to the TV,its just like as you would,do to connect a laptop to a LCD projector etc..
  • Lalit Varadpande
    your welcome,do buy the correct ones!
I am trying to connect my acer PC to a tv but get
The inputs on a TV are normally via the ariel and go into a pre-amp
To get a signal in you, would again, normally connect to the RGB or Video in which bypasses the pre-amp.
The VGA cable will be outputting a digital signal which a monitor will understand but a TV will not as it prime supply is via an analog signal
You may be able to get a connection if you process the signal through a freeview box which changes the signal from analog to digital
Jul 01, 2009 | Acer Aspire 5102WLMi Notebook
Information on Acer 1642 WLMI battery
The replacement battery you mention is High capacity battery that will work with your laptop.
186508APTA 14.8 Volt Li-ion Laptop Battery (works with Acer Aspire 1642WLMi).
14.4/14.8V, 4400mAh
  • This battery only compatible with 14.4V and 14.8V version.
  • New 100% OEM compatible
  • Guaranteed to meet or exceed original specifications
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    May 15, 2009 | Acer Aspire 1642WLMi Notebook
    How can we connect acer aspire 5001 wlmi to panasonic plasma 42' tv
    You have TWO OUTPUT from the laptop: VGA and RCA Video Out (Yellow connector). Now match one of these in your plasma TV and you are on your way to fame. Remember to select the video source on your TV, possibly A/V input.
    Apr 19, 2009 | Dell Precision M60 Notebook
    I have acer 5610 i want to know if i have video out or no
    Your PC has a VGA out port. However I think you mean does it have an analog video output that you can connect to a TV or similar device. Yes, there is TV output and S-Video output.
    Jan 26, 2009 | Acer Aspire 5610-4648 Notebook
    Help
    Step 1
    Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
    Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
    Aug 09, 2008 | Computers & Internet
    Acer Aspire 1642WLMi Notebook Logo
    698 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
