Question about RCA HD52W59 HDTV Projection Television
Hd52w59 convergence fuse
The other day i jumped the fuse and after about 15 mins the tv started turning on and off
  • brady bowling
    brady bowling Nov 30, 2008
    flyback connections what do u mean
    are u talking about where fuse is soldered into board
    Genius:
  • 1,030 Answers
You jumperd the fl231 fuse? did you resolder the flyback connections. if these are not resolder the oscillation can still cause probklems
Posted on Nov 30, 2008
Rca tv modle #hd52w59 convergence problem need to know cong.location
if you need to know where the convergence settings are you click menu then setup and then convergence. I have the same tv as you and the picture looks like its 3d with red and green and the words on menu are doubled and I tried auto converge and it didnt work. If you figure it out let me know. it also might be a fuse.
Nov 01, 2010 | RCA HD52W59 HDTV Projection Television
Tv started ghosting in red green and blue
The tv is have a problems call convergence,it dead.U have all the tools like soldering iron,solder and desoldering pump.Know basic soldering?The convergence fuses FL231 three of them on the right side of FBT,a big block of plastic of a flyback transformer.Resoder the FBT,replaced the convergence fuse FL231 in the middle.The Ebay.com sell the convergence fuse.
Aug 25, 2010 | RCA HD52W59 HDTV Projection Television
TV RCA HD52W59 NO VIDEO
Sound like convergence supply problem (small fuse near flyback will be open.
Sep 17, 2009 | RCA HD52W59 HDTV Projection Television
Where are the convergence chips and resistors (pico fuses) located in the rca hd52w59 hdtv projection tv?
There are none in that chassis. You can get the convergence option missing repair kit at the following link and the kit contains the parts and CD with instructions. www.tvrepairworld.com
Sep 12, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 convergence problem
Point-by-point convergence can be set by a good technician, but the controls are not accessible to the customer. also check the fuse in the power deflection board.
Jul 26, 2009 | Televison & Video
52' take about 15 min. to come then only stay on for about 1hr
The convergence ICs overheat , you get bad picture and then the TV detects the fault and go in protection mode, that is the standby state.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Mar 09, 2009 | RCA HD52W59 HDTV Projection Television
FL231 RCA HD52W59
You dont want to leave that fuse jumped, as it blows when there is a problem with the convergence power supply, and if the power supplt surges again with that fuse jumped you will destroy the convergence power supply and the deflection board and the cost would be in excess of 500 for those two boards.
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Projection Big Screen TV
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply problems....in which has to be replaced or repaired,
May 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
