Question about Cameras
My camera keeps running out of batteries after ever 2 or 3 photos whys that
    Problem Solver:
  • 16 Answers
Change the battery to recharger battery minimum 2000NiMH for normal use,if can use the 2500 to 2700NiMH,reply me ,rose89my@yahoo.co.uk,thk!
Posted on Nov 27, 2008
My acer 6920 keeps saying no battery is detected
check that the replacement battery casing is not warped by an overheated previous battery stack. Same issue with this laptop.
Apr 05, 2013 | Acer Aspire 6920 Notebook PC
Tip
After each photo shoot, prepare for the next one
After each photo shoot:
1) transfer all photos to computer
2) format memory cards in the camera that they are used in.
3) charge all batteries
4) check lenses for dust and such. Clean as necessary. Use air if possible. If not, use something designed for the purpose.
The next time that you go on a photo shoot, you will be prepared with freshly formatted cards, and fresh batteries.
There is nothing more bothersome than not having enough memory cards for photos.
Another tip.
Use smaller capacity memory cards, this way when, not if, they fail, you will not lose all of your precious shots. Keep cards numbered, and have a pad and pen in your camera bag, with the subject of photos for each card. Also, keep your camera's manual in the bag, for a quick reference when you are out in the field.
on Dec 17, 2009 | Cameras
I want to take star photos, how do I keep the apiture open (with a shutter cable) I tried but it doesnt stay open!
Set the mode dial to "M". Turn the command dial to set the shutter speed to "B". The bulb setting leaves the shutter open as long as the shutter button is held down, or fifteen seconds, whichever comes first. Unfortunately, that fifteen-second limit is much too short for good star trails. This is a limitation of the camera; there's nothing you can do about it.
This is a common problem with point&shoot cameras, even the advanced models. They're okay for 98% of the photographic situations you might encounter. But for the other 2% they either can't do it at all or make you go through hoops to do it. Just about every DSLR has a bulb mode that keeps the shutter open as long as you hold down the button (or better, yet, between two presses on a remote control unit so you don't even have to touch the camera), or until the batteries run out (and in those cases you can use auxiliary battery packs or just plug the camera into line power).
Apr 27, 2012 | Fuji FinePix S7000 Digital Camera
How can i download pictures from my A1000 w/o the sotware?
There are several ways. Download and install google's picasa. When you connect your camera click the Import tab and follow the appropriate steps to download the photos. It does take time to learn and you may make a mistake so be sure to keep the option not to delete the photos from the camera after download.
2- The safest way is without any software. Connect the camera and go to Start/My Computer where your camera will appear next to C: (or D:) as E: or some such volume. Click on folders there until you see your photos. Copy the enclosing folder and paste it somewhere like the desktop or My Pictures. I usually prefer to save duplicate copies one on an external hard disk.
3- Same as 2, but also use www.irfanview.com to sort and display your photos.
4. Same as 1., 2. and 3. but instead of a USB cord connecting the camera use an memory card reader. That saves your camera battery for one. It also allows you to delete photos in the trash of the memory card (not the one n the desktop).
Dec 17, 2010 | Canon PowerShot SD1000 Digital Camera
WHAT BATTERIES GOES IN THE CANON EOS REBEL G
LR23 batteries - they can be found in Walmart's photo center in the battery area. They run about 10-11$ after tax for 2 batteries
Oct 21, 2009 | Canon EOS Rebel G 35mm SLR Camera
Not ale to dowload photos to my laptop
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
May 14, 2009 | Canon IXY 1000 Digital Camera
I turn the camera on and the screen shows blue with a no image sign. Is it stuck in some mode where its looking for photos? The card is clean and empty. I cannot take any photos. I also use a...
Check the mode selection switch. It should be adjusted in the mode you desire to work. Also click the shot button and keep it pressed for about 2 seconds. If still not working properly then switch off the Camera and remove the battery and replace it after about 2 to 3 minutes and then try again.
Jan 23, 2009 | Fuji FinePix S5000 Digital Camera
Network
try sim with other fone on same network, if prob cont. with other fone then contact your network.
If ok with other fone try selecting Menu>Settings>Press Navigation key right to find Connectivity>Scroll to Mobile networks>Select GSM/3G networks>Turn phone off>On.
If this doesn't work you will need to take your fone to a service center.
Jan 21, 2009 | Sony Ericsson K770i Purple 3G Camera...
Turns itself off every time I try to take a photo
I had a similar problem with my Cyber-shot S600. It just turned off every time I tried to take a photo. I bought a Sony recharger + batteries and it fixed the problem. Camera works fine and I'm impressed with the how long the batteries last between charges.
Jan 04, 2009 | Sony Cybershot S650 Digital Camera
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
