Question about JVC LT-42X579 42 in. LCD TV
Blue light My JVC LT-42X579 blue light stay on won't turn off and the tv won't respond nothing happens by pressing the OFF button it just won't turn ON or OFF what can i do? Please I need Help
  • 2 more comments
  • jcstarr01 Dec 08, 2008
    The blue power light is flashing on and off and I can not turn my T.V. on. I have tried unplugging it, turning it on with the remote, turning it on, on the side of the TV with no luck. What do I need to do to fix it?
  • robbo3162002 Dec 21, 2008
    I have the same problem- tv was working fine last night, and now nothing, just a solid blue light, then flashing and the tv makes a "click" sound like it's turning off. JVC offers no call-in service, only email. very frustrating
  • utencilio Feb 20, 2009
    Hey, same here... It is really annoying because me TV is barely passed warranty this month. If anybody finds out how to fix it, it would be greatly appreciated.
  • Anonymous Mar 19, 2014
    I need the base that fits this tv.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Posted on Feb 20, 2009
  • 1 more comment
  • shellie0730 Feb 12, 2011
    THANK YOU THANK YOU THANK YOU! This fix worked fabulously. After searching through manual, online JVC website, calling JVC, and calling a local repairman this was the only thing that worked! WOW!
  • G-man 58 Feb 20, 2011
    To all those frustrated with this problem as I was. No worries. Worked like a charm. Thanks to you who figured it out!! Kudos!
  • jmiller6538 Aug 04, 2011
    You are the Man (or woman)! works perfectly! Thanks for saving me a trip to the TV repair shop.
I have a pyle pldn72bt and it was working but one day it just went blue the screen stays on blue i could move the mode settings but nothing will show
Check and replace its tuner. It is at its main digital board. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 10, 2017 | Pyle Televison & Video
Problem I can't intall my product many times its turn off itself all my installation are well install with my blu-ray ARC tv to ARC Blu-ray are well install I don't understand why its turn off itself
The blue ray turns off or the TV? and what models?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 07, 2017 | Televison & Video
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
My alba telly won't turn on it glee ps flashing blue what should I do
Sounds like your power supply inside the unit is bad. What is the make and model?
Mar 11, 2013 | Televison & Video
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
URC-22B doesn't work with my BEKO tv.
Check with this method. Manually turn on your tv.
Then push and hold the code saerch button until the light stays lighted release the button.
Push and release the device button you want to set TV.
Now you got to push and release the ON/OFF button until your device turn off when your device turn off stop and push and release the enter button for storage the code.
Warning: You may push and release the ON/ OFF button for almost 200 times.
Good luck.
Jun 12, 2009 | Televison & Video
TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Jun 25, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
JVC LT-42X579 42 in. LCD TV Logo
1,356 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
