Question about Logitech Z-5300 Computer Speakers
The whole system won't turn on
My system is a year and a half old. One day, by mistake I flicked the switch off with my foot. When I tried to turn it back on, it only got on for 2-3 seconds, then the red light faded away. I thought it was the fuse. I've put a new fuse, a 3amp and it blew the fuse once again. But this time the fuse was all black, not like the original, the original was yellow and it looked like it wasn't good anymore. I would like to know if my system is damaged for good, or if I still have a chance to save it. I tought maybe it was the fuse that was not strong enough. I would like to know what fuse this system needs, cause im pretty shure the old one was a 3amp. If it's not the fuse can you help me? thanks! J.P
  • Anonymous Apr 18, 2009
    bought 4amp and 3 amp didnt work! gonna go get a 6amp and try! all slow-blow still burn out black!
Go to Logitech support and check the faq's on your speakers. You must replace with the same fuse and it may be a 3amp slow blow fuse. If so replace with the same fuse or you will just keep blowing them out.
Posted on Jan 16, 2007
SOURCE:
MY DURAFLAME HEATER COMES ON BUT ONLY BLOWING OUT COLD AIR?
Sounds like something in the control module. I have 2. One bought used about a year old. Lasted about 3 months and something in the control module or panel died so would not light or power up. I hard wired the blower and Infrared bulbs to manual switches so I can manually turn on and off heat. Have separate switches so can leave the fan blowing after turning off the elements to allow them to cool. The other heater was bought new and laster about a year and a half. Then the thermostat reading worked and fan worked cycling as should but elements would not light. Did a factory reset holding power button while plugging in. That fixed it for a day then back to same. took back off and while trying to trouble shoot voltages on the power supply module the elements started working again. Not sure what the issue but seems to be a definite issue with short lived control modules. To date have not found a resource to buy new control boards or other replacement parts besides bulbs which with the fans seem to be the most durable part of the whole heater.
Feb 20, 2013 | Duraflame Heating & Cooling
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
Just quit. Worked fine one day. Next day went to turn it on and nothing happened. Fan is little over a year old.
Control switch, circuit breaker, or loose wire are main suspect.
Rarely does a motor just stop working.
Check circuit breaker.
Open control switch and test for power and check for loose connections.
Install ordinary on-off switch and see if function resumes.
Check wire connections at fan.
Jul 11, 2011 | Air King 9166 20" Whole-House Window Fan
My van has an old security system it dosnt work since tow three years.Now a days my vehicle starts it remain one or two days works whenever I start but some time it didnt start. I left for whole night...
I agree with the mechanic..
I would have someone remove the security system all together from the van...
You dont mention what model van ... or year... so it's hard to discern what to do from this point.
Oct 06, 2010 | Vehicle Parts & Accessories
The lens is blocked half way and turning on gives only the indication: "Warning !! Remove Lens Cap!" and "System Error". How to fix it?
I just flick mine open the rest of the way and keep shooting as iv'e dropped min too many times and keep it in a jacket pocket that gets steppd on and rained on so I'm just banking some money for the day I can't just flick it open again. I sell digital cameras and your almost ready for a new one I dont worry about repairs just will I have enough Jack to buy another one when this one don't go no mor.
Aug 28, 2010 | Cameras
Very hard to kick start
i dont know what your timing is relevant to flicking the compression switch and kicking, but get the engine to the compression stroke and then as you go to kick it hard, flick the switch at that moment. timing is everything. i had an old yamaha tt 500 that kicked back so hard my foot slipped off the kick start and kick lever came up and took the skin off my shin.. it took quit a bit of time to get the timing but once i did, it was easy.. hope this helps.
May 19, 2009 | 2005 KTM 640 LC4 SM
The sound has quite working
First, NEVER turn the volume all the way up to see what's wrong. If HALF volume doesn't work you're only risking a catastrophic speaker blowout if you should suddenly flick the switch that's causing the problem with FULL volume on.
Look for the MUTE or Volume +/- controls on the remote and indicators.
Apr 12, 2009 | Yamaha HTR-6030 Receiver
Home cinema
yes kilshpsh ones at best buy 299 whole set they rock or u want whole system x40 samsung very nice sound ok 199
Dec 30, 2007 | Yamaha DSPE390 Amplifier
Logitech Z-5300 Computer Speakers Logo
1,216 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
