Question about As Seen On TV Easy Stitch Mechanical Sewing Machine
Threading... How do I thread my Easy Stitch Machine?
  • jaeger1442 Dec 09, 2007
    I don't know how to thread it or work it, the instructions are ridiculously unclear!
Take a look at the instruction manual on the JML site @ http://www.jmldirect.com/downloads/instructions/easy_stitch.pdf
Even if you have the instruction manual supplied with the machine as the pdf has colour images that make it easier to follow rather than the over exposed black and white splodges in the supplied paper manual.
Posted on Jun 08, 2009
Getting my delta overlocker fy14u to stitch, cant get a chain started
Most often, the problem either has to do with mis-threading or the machine has been knocked out of time. (It took me an entire day to thread my serger correctly the first time.) Start out with no thread in the machine. Follow the instructions "exactly." ALWAYS RAISE the presser foot when threading and be sure EACH thread is threaded in the correct order! Another helpful hint is to give each thread an extra little tug when going from the thread tree to the thread dial. This helps the thread seat completely in the tension disk.
Apr 23, 2018 | Sewing Machines
Have a Empisal S4D overlocker being threaded as per manual but do not stich can you help?
Be sure to ALWAYS RAISE the presser foot when threading the machine.
Unless the machine is out of time, the usual cause of stitch failure is that the threading is not correct. If the threads are not threaded in EXACT order and/or any of the threading steps are out of order or missed, the machine will not stitch properly.
You can always take it to a repair shop and ask them to check it for you.
Nov 14, 2017 | Sewing Machines
My 905 Huskylock was stitching just fine. I changed the thread last night by tying on new threads but one of the knots got caught in the tension plates. I cut it out and rethreaded the machine. It will...
It just may be that you haven't seated the thread in the tention disc, put on hand on each side of the disc when threading and push down to be sure its seated, I don't reccomed that you just 'tye' the treads to change colors, may I suggest that you practice threading your machine, it will come as second nature and really is very easy to thread
Aug 13, 2010 | Husqvarna Huskylock Computerized 905
Hi i just got a new brother 1034D serger. And I'm
I found that I had to remove the stitch finger to thread the machine properly. Do remember to re-install it before starting to sew. If you are using 3-threads only, then remove and store the stitch finger.
Puzzled that this instruction is not in the threading section of the manual.
Jun 23, 2010 | Brother Lay-In Thread Serger Mechanical...
Hi, I am unable to do a overlock stitch , elna l1
Check with sewusa for a threading guide and manual.
Look inside the font door of the machine to see if there is a threading guide.
Feb 28, 2010 | Sewing Machines
My top stitch is flat, but the bobbin is bunching and looping extra thread. cotton fabric, polyester thread
What looks like a bobbin problem is sometimes the threading of the top thread.
If you threaded the machine with the presser foot down, the tension is closed and the thread cannot enter as it should.
Improper seating of the thread into the tension results in loopy stitching as the thread is not being guided at the proper tension to create a satisfactory stitch.
Try re-threading the machine with the presser foot up.
Feb 18, 2010 | Bernina Virtuosa 160
Sewing Machine: loose stitch that's easy to pull out.
Check that the upper and lower threading are correct. Check that the thread has tension from the bobbin case.
Jul 23, 2009 | Sewing Machines
Top stitch looks good, bottom stitch is loopy
this is a common problem, don't worry it's easy to fix.  take the spool of thread off, remove the bobbin.  look for any stray thread pieces in or around the bobbin case, rethread the top of the machine and when you do, follow the threading guide precisely and ---here's the trick---make certain that the thread goes between the tension discs.
Jan 17, 2009 | Singer 3116 Simple
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
As Seen On TV Easy Stitch Mechanical Sewing Machine Logo
1,323 people viewed this question
Top As Seen On TV Sewing Machines Experts
R.A. Ellis
R.A. Ellis
Clive
Clive
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
