Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 restarts
Anytime I try to print, scan, or whatever, an error message appears in the small screen at the front of the printer (Fatal at line 787...) before it restarts.
sandrew
  • 2961 Answers
SOURCE: lexmark p4350
as you didnt post your operating system, go to the link below and choose it http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0
Posted on Sep 16, 2007
  • 41 Answers
SOURCE: error 2200
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Maggie B
Posted on Feb 21, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark P4350 AIO incorrectly identifies cartridges, will not allow printing
Some times refilled cartridges works fine,and in Lexmark cartridges
they do not support refilled onces ,Try a new compatible cartridge it should print ..
Posted on Mar 11, 2008
  • 300 Answers
SOURCE: I have a Lexmark T632
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Posted on Dec 10, 2008
SOURCE: i have a p4350 all
Try running c:\drivers\printer\4300\applications\setup.exe
Posted on Jan 16, 2009
After scan, whatever save function is used the error message "printing application has stopped working" appears with the only option Close Application.
Try to re-install the Lexmark X4650 driver. Visit the Lexmark website at http://bit.ly/iofMNC. Select your operating system, download the driver and execute the file.
Jun 18, 2011 | Lexmark X4650 InkJet Printer
Printer willnot scan
Try to unplug and replug your printer into the power outlet in the wall to reset it. Then try to scan again. Are you getting any error messages on the printer or on your computer screen when trying to scan? Can you try to make a copy? If scanning or copying is not functioning, it could be a hardware problem.
May 14, 2011 | Lexmark P4350 All-In-One InkJet Printer
Error 1102 Refuse to print PC screen says incompatible cartridge although I'm using original lexmark cartridge.
The 1102 error message is caused by a communication failure between one of the cartridges and your printer. Please visit the Lexmark website and refer to this article on 1102 Error Message on the Lexmark P4300 Series All-In-One. If you need additional assistance, please contact Lexmark technical support.
Hope this helps.
Feb 25, 2011 | Lexmark P4350 All-In-One InkJet Printer
Printer wont comunicate with Computer
Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect to your computer. Try to print again. If problem continues, you may refer to these articles in the Lexmark website:
- Communication Not Available' Error Message and Print Job Stalls in Print Queue - No Communications Error When Trying to Print or Scan
I hope these help. Thanks.
Feb 16, 2011 | Lexmark P4350 All-In-One InkJet Printer
We have a lexmark p4350. we cant get it to print
The error indicates an error in communication either between cartridges or the cartridges and the printer. Here's an article in the Lexmark website on 1203 Error Message on the Lexmark P4350 / P4330 Photo All-In-One. Just click on this link: http://bit.ly/9sK9hE. This should guide you on what to do.
Jul 05, 2010 | Lexmark P4350 All-In-One InkJet Printer
Drivers won't download
Use this link to download: http://www.download.com/3120-20_4.html?tg=dl-20&qt=abby&tag=srch
Mar 05, 2008 | Lexmark P4350 All-In-One InkJet Printer
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
P4350 paper jam error message. Definately no paper jam!!
try to follow the paper path as best as you can, from where the paper is picked up till it comes out, visually do this with the printer off, there should be a sensor (small plastic part that moves a little this tell the printer where the paper is at during the printing process, this sensor is probably stuck. 9 times out of 10 this is the problem.
Dec 27, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
89 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
