Question about Dishwashers
MY TECHNIKA DISHWASHER WONT DRAIN THE WATER SO IT STOPS HALFWAY IN THE CYCLE. THIS HAPPENED BEFORE AND THE TECHNICIAN MAUALLY DRAINED IT BY PRESSING A SERIES OF BUTTONS AND IT WORKED FINE. WHERE CAN i FIND OUT WHAT BUTTONS TO PRESS TO DRAIN IT MYSELF. THANKS
  • maestrolb Apr 28, 2009
    Dishwasher stops half-way through cycle and then beeps with three out of four lights flashing. Previously drained it myself and pressed button randomly - worked. Now happened again but can't get it to work again.
  • Dally girl May 10, 2009
    My technika dishwasher won't totally drain but still completes it cycle... The water level in the bottom is just getting higher each time
  • 76 Answers
SOURCE: dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Posted on Jun 29, 2007
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
  • 25 Answers
SOURCE: dishwasher will not drain
iMost often something has just jamed the drain impeller, take out the filter plate in the bottom, then in the sump to the right side is the cover to the drain impeller. It has one screw in it a
T-20 torx take that out then lift up on the cover. After that use your finger to turn the impeller if it is jammed you will need to find what is blocking it then reassmble
Posted on Feb 16, 2008
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
SOURCE: Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Posted on Feb 26, 2008
Dishwasher was not draining. I cleaned out everything and now it wont start
I have the same problem with another Kitchenaid model. I've had better results at keeping the water drained by running two back to back water saver cycles than running a full pots and pans cycle.
Nov 06, 2017 | KitchenAid 24 in. KUDS01FLSS Built-In...
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Water will not drain .cycle stops , will not start even on new cycle
The water will have to be evacuated first. there may be a blockage either in the outlet of the dishwasher or the drain connection under the sink. The dishwasher tries to drain at the very start of the cycle. If this doesnt happen then a new cycle wont start.
Jul 31, 2010 | Dishwashers
Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
May 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
Bosch dishwasher has standing water doesnt drain out, repair man pushed 2 buttons cancel drain and it drained last month, but happened again today and it wont work for me
Fixed mine very easily... After checking and cleaning the filters by the tub's drain, I checked the air vent atop the sink -- it had a small bit of gunk trapped in the outlet. Cleaned it out, ran a "rinse & hold" cycle and it drained the tub beautifully!
Apr 22, 2009 | Bosch Dishwashers
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher will not drain water out after completing the rince or final cycle
hi there,
check to see if there is anything stuck in the pump. if there is nothing and the problem persists, have the technician replace the drain pump.
May 02, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
740 people viewed this question
Top Dishwashers Experts
