Question about Adobe Acrobat Professional 7.0 for PC
Adobe Acrobat Pro 7 Application Errors
I am getting consistent "Application Errors" with memory addresses whenever I edit a file in Adobe Pro 7. The change(s) record successfully and I am able to continue with my work afterwards but the error message is annoying and it slows me down considerably.
The Application Error reads as follows:
The instruction at "0x0308bd2b" referenced memory at "0x0350ea71". The memory could not be "written".
Click on OK to terminate the program.
Hope you can help.
-Dan
  • Anonymous Apr 08, 2009
    The instruction at “0x0308bd2b” referenced memory at “0x0350ea71”.
  • 39 Answers
Please visit this link to resolve your concern.
Link:-
Posted on Sep 06, 2009
"Pick..." List on the Calculate tab of Text Field Properties in Edit field mode in Adobe Acrobat 10
http://adobe-flash-player-non-ie.soft32.com/ 11.4.402.278Free Adobe Flash Player is a cross-platform browser-based application runtime. Hope this helps.
Jan 18, 2013 | Adobe Acrobat X Pro
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
Cannot edit text in acrobat x pro
you need to uninstall ,format device and re-install next put your characters on the acrobat x pro file you can do it by go c drive program-file,acrobat x pro click it add file again it will work.
Jan 08, 2013 | Adobe Acrobat X Pro
While using Adobe Acrobat sometimes my screen turns into unreadable characters. Am using windows 7 and Adobe 9. Any suggestions. Does not happen all the time.
I would try to do a repair install on Adobe Acrobat 9. To do this, open your start menu and type "appwiz.cpl" and press enter. This will open the Add/Remove Programs. From there, find Adobe in the listing and hit Uninstall/Change.
Next follow the Install Wizard to Repair. This may take awhile and if files are severely damaged, it may request access to the Adobe installer or disc.
This resolves a lot of strange errors with the software.
Mar 07, 2011 | Adobe Acrobat Pro 9 Upgrade
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
Suddenly all my pdf docs are opening in Adobe reader instead of Acrobat Pro. Even the Acrobat.exe file in my C:Program Files\Adobe\Adobe Acrobat 7.0\Acrobat folders opens Adobe reader instead of Acrobat...
Go to My Computer. Tools > Folder Options > File Types > Then Browse PDF Registered File Type . If you can see " Details for PDF extension " and you can see a change button, you can click that button and browse for your Acrobat Pro main program .
Aug 18, 2009 | Adobe Acrobat 7.0 Professional
Acrobat 7 Pro - combining multiple pdf to single pdf errors
https://acrobat.adobe.com/in/en/acrobat/how-to/merge-combine-pdf-files-online.html
Mar 16, 2017 | Adobe Acrobat 7.0 Professional
I am getting Application Errors in Adobe Acrobat Pro 7 whenever I edit a file.
try uninstall the program and restart the computer and install the program again.
may this help
melnavz
Nov 27, 2008 | Computers & Internet
Help with adobe 7.1.0
In order to edit a PDF document, you will need either one of Adobe's commercial Acrobat products or a similar third-party application.
You can often copy the contents of a PDF document to a word processor or text editor program (e.g., Microsoft Word or Notepad) and then edit them, but in this case you cannot resave the document as PDF (unless your word processor specifically has the ability to create PDF files).
To copy the document's contents:
from the Adobe Reader Edit menu,
choose Save as Text.
Alternatively, from the Edit menu, choose Select All; then, from the same menu, choose Copy, and then paste the text into your word processing program using that program's paste function.
May 07, 2008 | Adobe Acrobat 7.0 for PC
Adobe Acrobat Professional 7.0 for PC Logo
178 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
