Open buffalo ministation case...did you figure it out?
i am trying to open my ministation case and have the same problem.
did you find a way to get the case open?
i think something must slide after the screws are removed, but it doesn't seem to budge.
if you have any help please email me
sean@coconutlogic.com
thank you
Haven't figured it out yet then here's how.... undo the four obvious screws. The ni the mifddle at both sides there's tow 'stick out' bits from the attached to the middle sides on the bottom bit of the case. First you pull the two ends up and twist a bit and use more force than you think you should. CRACK it comes apart. Next itme, better if you do this first time, push a small screwdriver carefully against the grey liner in the mifddle at one side whilst holding open the tow end on the same side. Less of a crack and less force but more hands needed and it open. Cheers from Knobcottage
Posted on Jun 06, 2009
My hard drive is not recognized in my mac. The light is blue, neve turns to green
Have you tried to connect the drive to a different computer? You can also try to open Disk Utility (use spotlight search to find it). My guess is it doesn't show up there which means there is a problem with the Buffalo device. The disk is most likely fine, just the Buffalo casing needs to be replaced.
Apr 23, 2014 | Buffalo Technology Buffalo 1TB MiniStation...
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
Harddrive enclosure
depending on the size
2.5" if it's a small one (no power adaptor needed)
3.5" if that's the big one (desktop hdd with power adaptor)
Jul 24, 2013 | Buffalo Technology Buffalo MiniStation...
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
I have had my current Buffalo MiniStation Plus HD-PNTU3 for almost about a year now without an issue or problem but recently it refuses to open on another computer while it works fine on my own. I am
The device probably can with a Buffalo utility/driver disk. The other computer will need these drivers to recognize the device. If you lost the driver disk, you can download them here: http://www.buffalotech.com/support-and-downloads
May 31, 2013 | Buffalo Technology Buffalo MiniStation...
Driver for HD-PNTU3
This drive showing as not supported for Linux as you mentioned.
Usually this is due to the board inside the enclosure.
You could crack open the case and mount the drive internally which would resolve this issue.
Otherwise you are down to trying to find a driver (not made for this model) that will be recognized by your system.
regards,
Mike
Sep 25, 2012 | Buffalo Technology Buffalo - Hdpnt500u3s -...
How to open the case safely (without damaging it)?
Remove all screws from the enclosure, and then slide a then metal (non magnetic) slide to pop the clips off of the sides of the enclosure, lengthwise. You can do it without breaking the plastic
Jul 13, 2008 | Buffalo Technology MiniStation Turbo 120...
Computers & Internet Logo
3,599 people viewed this question
Alun Cox
David Payne
David Payne
