Question about LG Televison & Video
I have an LG RC388 DVD Combo and not sure how to record VHS to DVD ? Would appreciate some help please
    Problem Solver:
  • 16 Answers
You need a "TV in" graphic card (an analog input)
Posted on Nov 27, 2008
Good product, but the manual is rubbish.
Check out 'dubbing' in the 'manual' andthis will more or less explain how to record from VHS to a recordable disc.
Also check out 'finalizing a disc' on the onscreen menu to be able to play the disc on any other player.
Posted on Jan 20, 2009
LG DVD VCR combo recorder RC689 doesn't record in VCR
I see a RC689D model. It DOES record via VHS and it should do so as you have done before. Go through all of the steps in making sure the tape(s) you're trying to use isn't missing the "Safety" tab, look at the tape to make sure there are no defects, and make sure you are receiving a signal to the VCR. With most signals being "Digital" and not analog, I would assume you are trying to pull your signal from either a digital box, a Satellite feed, or a cable feed.
Try "Daisy chaining" your VCR from your output box using the following method(s):
Signal coming to box> (1) Coaxial or Cable hookup from box to VCR> (2) Red White Yellow connectors from source to VCR> VCR output using same method(s) as input from source to TV> make sure your TV is set to the correct channel; usually notated as either channel 3 or 4.
If you cannot get the VCR to record correctly, and you have checked and verified all of the input\output cables are properly seated, and you are getting a signal from the VCR to the TV, then it is possible the unit may just be faulty, in regards to recording onto a VHS tape.
Hope this helps.
May 01, 2017 | Televison & Video
LG DC593W - DVD & VHS Combo
hmmm..ok...sounds like a video setting issue on the way'll need to go to the menu, and reset the input settings, so it's in alignment...
May 27, 2008 | LG DR-4810 DVD Recorder
Lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
Mar 15, 2012 | LG XBR446 DVD Recorder/VCR
Hi There, I want to know how to copy from VHS to DVD on the LG RC185 - I have the equipment but not the user manual! Also could you please instruct me on how to make sure the DVD will play in all DVD...
I am glad you asked. The free user manual for this model is available as a pdf document and can be downloaded from the following site:
(no email, security verification or registration required, just go there and click 'get this manual')
I hope this helps you or at least offers some guidance for you in VHS to DVD recording with your combo unit.
Apr 20, 2011 | LG RC185 DVD Recorder/VCR
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
How do I get an owner manual for this product?
its here for free, available in pdf format will need adobe acrobat or similar.
please rate :)
Feb 14, 2010 | LG RC389H DVD/VHS Recorder
How do I record my vhs onto the dvd?
How about a USER MANUAL instead :D
Please note this unit is NOT a DVD recorder. It only has a DVD ROM drive to play DVDs - not to record to them.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 30, 2009 | Samsung DVD-V4600 DVD Player/VCR
How do I unlock my LG RC388 to play other region disks
YES, it can be changed to view all regions. I've just done my new RC388 (bought it 4 hours ago) and it works.
To start the hack:
Click the home button on the remote, go to the Setup page, highlight the 16X9 TV aspect ratio and enter in this coded sequence: 1 3 9 7 1 3 9
A new factory menu now comes up on the screen.
To change the values of these options hit the enter button and scroll with arrow keys until you get to the option you want to change. For the region code hack replace the value of "option 5" with the value of: ff
Press enter.
(Changing this value will set unit to region code 0 which should allow any region to be played on the player.)
Now, hit the "return" button to save and exit.
Switch off the machine - switch on - all is well now.
Good Luck,
Mar 31, 2009 | Televison & Video
Finalize the disc within the on screen menu. That's it.
Feb 18, 2009 | LG RC-197 DVD Recorder/VCR
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Televison & Video Logo
677 people viewed this question
Computer Repairing
Computer Repairing
