Question about Toshiba Computers & Internet
I need to reset bios password I tried with removing cmos battery it didnt work
  • 849 Answers
A switch beside of battery needs to turn on for resetting.
Posted on Nov 27, 2008
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
Hello : my problem is i have laptop acer model 5230z : i cant access to the bios becuas is encrypted in passwoed and i try all way that found in web put is no result thank you i hope be help me
There are four common categories of solutions to remove or reset a BIOS password and here are the details on how to go about resetting your BIOS password.
Manufacturer Backdoor BIOS Password
Most of the BIOS makers have set a backdoor password on the older computer models. That is the master password for BIOS. To reset BIOS passwords first you need to check the manufacturer of your computer's BIOS. Most computers have BIOS include AMI,
IBM, Award, and Phoenix. These are the most common BIOS. You can unlock your locked BIOS using this master password. It works, no matter what the user sets the password to. Many popular computer and laptop manufacturers such as HP and DELL lock the BIOS because they want to protect their machine's most sensitive areas (those areas which have warranty) from their customers. These passwords are usually used by computer technicians for testing and repairing.
Reset the jumper that holds the password
Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.
Removing the CMOS Battery to reset the BIOS to default
Switch off your computer, and open up the case. You'll see a circular metallic silver item on motherboard. This is called CMOS Battery. Remove it carefully, and leave it out for about 2 minutes. This act will remove the CMOS memory which contains BIOS password. Set the CMOS battery back and switch on the computer. Restore the CMOS configuration as default. Your BIOS password has been cleared now.
Using third party software utility to reset BIOS password
To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website http://www.hirensbootcd.org/. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
Please let me know whether this works or not.
Dec 26, 2010 | Computers & Internet
I have a Wipro Laptop. His BIOS is Phoenix. It has a CMOS password. How shall I clear the password.\?
Hi Nayanranjani.
As you trying to reset the BIOS password, let me provide the required steps.
You may reset the BIOS password by just removing and inserting the CMOS Battery.
The CMOS Battery will have the Computer date, time and also the BIOS password saved in it.
Hence, removing and re-inserting the CMOS password will reset the BIOS password.
Once the BIOS password is removed, you may assign a new BIOS password.
Hope this helps.
Please feel free to ask further questions.
Aug 18, 2010 | Computers & Internet
How to remove bios password in toshiba satellite A305-s6905 laptop? i tried removing the battery,but it didnt work... it asked me for a JO pin,which i was unable to find.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don’t have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Jul 20, 2010 | Toshiba Computers & Internet
How can i remove the password in the HP MINI 1000 netbook while i did not even know my password it just came out asking a CURRENT PASSWORD? How can i reset the BIOS of HP Mini 1000?
remove cmoc battery from motherboard for a minute then connect it again password will remove
otherwise change bios chip is the only solution
Jul 16, 2009 | HP Mini 1000 Netbook
How do i remove bios password
There are many known ways to reset / remove / bypass the password:
* By removing the CMOS battery
* By using the motherboard jumper
* By using MS DOS command
* By using software
* By using Backdoor BIOS password
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
Mar 13, 2009 | HP Compaq Presario 2500LA Notebook
Need to reset bios password for acer 4620 laptop. tryed removing battery on mb . no good . ? passmord bios
Try removing the main battery and the CMOS battery (ie the battery on the mb). If you don't want to wait for 1/2 hour for the CMOS to discharge then short out the CMOS battery connections with a bent paper clip.
Then without instralling both battery, power up your laptop, you should then get into the BIOS, power off and re-install your batteries.
Aug 19, 2008 | Computers & Internet
Bios password
Try an locate the CMOS battery. it should be a little nickel battery in a yellow casing with a red and black wire connected to the motherboard. check near the ram, and the CD Drive. Once found, remove it. (including the notebook's battery and AC adapter) wait about 10 seconds, plug the CMOS battery back in, the actual battery, and the AC adapter if needed. and you should b e good to go.
Jun 05, 2008 | Dell Inspiron 1501 Notebook
BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
May 03, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
332 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
