Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Dos command plaese send dos commandes
  • good_choice6 Nov 27, 2008
    window xp learning
  • 488 Answers
DOS commands for XP are located here:
http://www.ss64.com/nt/
hope it helps!
Posted on Nov 27, 2008
Whte is my ip addres
Open a command line (e.g. run CMD to get a 'dos' prompt) and execute:
IPCONFIG
The line with IPv4 will have your IP address
Sep 20, 2011 | Linksys Wireless-G Broadband Router
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
The printer cannot be set to a page length when printing from a dos program. The page length is incorrect but changes with every print even though the same file is printed
Prints from DOS programs do not have a "page length" setting of their own, nor do dot matrix printer have a page length of their own.
Page feed is achieved by sending a special control code (^L), and the meaning of ^L can be set through specific escape codes that the DOS program has to know.
My guess is that you need to tell the DOS program the page size in lines or inches, and maybe instruct it to send a page feed command after each page.
You can try directly programming the printer, but if the DOS program is sending out the wrong codes, this is not going to help. Anyway, here goes. Good luck!
http://www.masondesigns.com/staging/dhl/printer/lasernet/turboset.html
Feb 01, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
How can I run a dos app without using a command prompt console?
vbscript should be able to do that you can swap between wscript ( which uses the gui ) or cscript ( which uses the command prompt )
May 07, 2009 | Computers & Internet
Hi i'm A ojt technician of computer and I encomtered the problem of computer the problem is system halted... what is the possible deffect of that problem. . .
it cannot find COMMAND.COM
Explanation: When you boot up DOS, you are placed at what is commonly called the "C: prompt", where you can type commands or run programs. The part of DOS that reads what you type and executes commands is called the command interpreter, which is stored in the file "COMMAND.COM". This interpreter is loaded when you start the system or when you start an MS-DOS session under Windows 95, and is also reloaded in some cases when you finish running a program. In this case, the system was unable to find COMMAND.COM and therefore halted the system.
try this
  • Make sure that COMMAND.COM is in the C:\ root directory, or if it somewhere else, that there is a line in AUTOEXEC.BAT that reads "COMSPEC=X:\PATH" where "X:\PATH" is wherever COMMAND.COM resides.
  • Edit the PATH command in your AUTOEXEC.BAT file, if you are trying to run a command in another directory that should be accessible from anywhere.
please send me a feed back if this works out thnk you.
Dec 12, 2008 | ASUS A7N8X-E Deluxe Motherboard
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Run dos command through vb 6.0 without showing it
visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
Mar 20, 2008 | Computers & Internet
How to write program for running the DOS,UNIX and LINUK command using C language
Dear Sagarshinde111,
Thank you for your excellent question on how to run all DOS and UNIX commands on a Frigidaire GLTF1670A Front Load Washer using the C programming language. I do not know specifically about washing machines, but there is a version of UNIX which has been ported to toasters that would be a good starting point. NetBSD is a full UNIX operating system written in C, and all the source code is freely available to use and change under the Berkeley License (which basically says, do what ever you like, but don't claim you wrote it). You can download it from netbsd.org. You will also find in NetBSD's excellent package source repositories (pkgsrc) the C source code for both DOS and Linux kernel emulation.
I am sorry that we were not able to help you in time for your class assignment (due the next day!), but perhaps this will help the next student who is given this rather challenging homework.
Mar 17, 2008 | Frigidaire GLTF1670A Front Load Washer
Message Sending from windows 2003 server
GO TO YOUR EXPRESS AND REPLY ALL. MAILS TO EVERYONE IN YOUR BOOK.
Jan 21, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
