Question about Canon EOS Rebel XSi Digital Camera
Camera says card write protected
Camera was working fine last night. When turned on this morning the camera's LCD displayed Card Write protected. I took the sd card out and it was NOT on lock. put it back in and attempted to take a shot and it displayed again. I tried a different SD card and it displayed the same error. I tried reformatting both of the cards and then attempted to shoot with both cards and again it displayed that there was a card write protected. I assumed that it was the cards, but wanted to be sure so i took both cards out and put them in my friend's nikon D80 and they both worked fine. I put my cards that i thought were giving me the error into his D80 and it too worked fine. I put his card into my Canon XSI and it displayed the same error. Last thing i tried was resetting all settings back to normal and then shooting. Again.. Same error. Please advise.
  • 5 more comments
  • Anonymous Jan 17, 2009
    I have the same problem too.
  • Anonymous Jan 30, 2009
    Seems to be related to cold/wet weather. Never saw this problem indoors
  • Anonymous Mar 10, 2009
    I have the same problem...too
  • Anonymous Mar 30, 2009
    Same problem for me too. Canon told me to try a slower card. I don't want to buy a slow card.
  • groovyglass Apr 24, 2009
    I was taking photographs and the camera worked fine. I loaded the images onto a laptop and about an hour later when I put the card back into the camera, it came up with the error message Card Write Protected- very frustrating! How can I fix it?
  • cjb123 May 24, 2009
    Has anyone found out the solution to this problem?...'Card write protected'
    I've tried everything and nothing seems to work.
  • Anonymous May 25, 2009
    says card write protected everytime
I just figured it out- on my memory card there's a small "switch" on the left hand side that you can slide up and down. Make sure that this is up the top, not down towards where it says Lock. If it's down, this makes the card Write Protected.
Posted on Apr 24, 2009
CanadaBruce
  • 58 Answers
SOURCE: Nikon D80 Exposure Count
Could it be that you are set in the "highlight" view?  Use the round selector in view mode to change the views.
Posted on Mar 09, 2008
DarrenP
  • 78 Answers
SOURCE: Problem shooting portrait
That's just the quirky autofocus of the d80. Try tilting the camera diagonally to focus and tilting back up to shoot.
Unfortunately, autofocus issues like those are the difference between a d80 and a d200/d300 :/
Posted on Apr 07, 2008
Steve5
  • 423 Answers
SOURCE: Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Posted on Feb 18, 2008
  • 8 Answers
SOURCE: SHOOTING ON A NIKON D80
1. Use Dynamic Focus. It enables you to track the animal if it is moving.
2. Focus on the animal's eyes. If the eyes are in focus, it will make the photograph.
3. I suggest spot metering with quick animals. It may wash out the background but you will get the shot of your 'prey'.
4. If the animal is stationary, stick between f8 - 11.
5. As far as possible, shoot just after dawn and before sunset. You get good light that way.
6. Try to frame the animal against the sky or some other light colour if the animal is dark or against a dark background (or the sky again) if the animal is light.
7. Switch off the beep sounds of the camera.
8. A good sturdy tripod.
9. Patience. Oodles of it.
10. I stay in Africa (for the time being) and enjoy photography. I usually go by these maxims. I hope they work for you.
Satdeep
Posted on Jun 18, 2008
E-man_1
  • 56 Answers
SOURCE: Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
Posted on Sep 09, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Every time I turn on camera,it displays CARD LOCK? and will not work
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 05, 2014 | Vivitar Cameras
Camera says sd card unmounted wont work was working fine last night
In the settings menu under storage there is an option unmount sd card every time before removing the card from the phone or tab you should press this option unmount sd card otherwise directly removing the card without sectiong the option causes these errors
Oct 21, 2013 | T-Mobile Cell Phones
Canon powershot sd 1000, memory card not detected
Please try to copy all the contents of your SD card to your computer. Then format the SD card and try it again on your camera.
If it still can't be detected, try another SD card.
Aug 08, 2012 | Canon Cameras
After a birthday dinner, i plugged my sd card into my computer to upload my pictures only to find that a couple of them were corrupt and couldn't even be viewed. I put the sd card back into my Canon...
Most probably the problem is in SD card. Please try a different card to check. Also perform scandisk on this SD card to check for errors.
May 14, 2011 | Cameras
Card error
The SAME thing is happening to mine as of yesterday.. I uploaded pics no problem yesterday morning, took more pics last night and then when I went to plug it in.. says card error. Tried other cards in my camera, its saying the same AND this card will no longer work in other readers.. Heeelp please!
Oct 30, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
Memory card not showing all pictures on camera
That doesnt mean that they have not been deleted after you looked at them this morning.
Remove the card and use a card reader to access the card to see ALL of the pictures currently on the card. This is like having a second opinion, both can't be wrong. The other aspect is that some pics are in memory and not on the SD card
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Nikon Coolpix S210 Digital Camera
Camera turns on and focuses, but cannot see menu or take pictures
two things here, have you checked to see if the location to store the pics if it is placed to the intenal memory and the memory is full
also pls try to take a pic with another SD card may be that this card is either corrupted or damaged
Jul 23, 2009 | Nikon D50 Digital Camera
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
I took some pics on my laptop built in camera last night n tried this morning to save them to my sd card so i could look at them in my digital camera, but even tho they r stored on the card, i know this...
This is because camera will show these pictures with specific file name/ number.  You need to check camera taken picture file name/ number and change uploaded file name/ numbers as camera firmware generate it.  Please change picture file name according to camera taken picture.
let me know if further help required.
Jan 06, 2009 | Nikon COOLPIX L12 Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
351 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
