Question about Zenith C36A26 36" TV
Static Sound along with Static/Jumping Picture.
We have a Zenith C36A26 that is 6 years old. Lately it has been making a static surge sound and the picture jumps around when the sound is present. It doesn't happen all the time, but it is becoming more frequent. Upon a call to Zenith, we were given 2 numbers for repair techs that were local to us. Unfortunately neither one repairs tube TV's anymore. They only service LCD and Plasmas. We will phone again after the holiday but we are wondering if this could be a serious or expensive problem. If so, perhaps we should be looking at a new one? Just seems like a TV should last longer than 6 years. I would appreciate anyones response. Thank you.
  • 905 Answers
This is just the tuner and it can be replaced or it just needs some soldering but i fix these and i can tell you it sounds like the tuner is failing and needs replaced , the tuner can be about $80 and the repair can very between 50 -$60
hope this info is worth a fixya as other ratings only hurt our rating
and if you need more assistance I'll be glad to help
Posted on Nov 27, 2008
Zenith r57w46 rear projection tv
the static sound may be due to a defect in the high voltage circuits, IE Fly-back transformer or and voltage multiplier, posibly high voltage leads to the CRTs arching to ground, finally horizontal sweep circuits
Apr 28, 2010 | Zenith R57W46 57" Rear Projection...
Loud static
The set isn't fully tuned into the channel the satellite receiver is outputting on (should be channel 3 or 4). If this set is old enough it may have a fine tuning adjustment that needs to be tweaked a little to clear up the problem. Some Zenith TV's also had a switch to select different tuning systems. If set incorrectly this might happen. If yours has such a switch, make sure it's set to "normal" or "air". It may also be that just due to age the turner isn't working properly.
It might be time to consider replacing that set. A new one would give you all the picture and sound quality your satellite can give you. Right now you're paying for quality you can't appreciate.
Apr 22, 2009 | Televison & Video
A ''static'' sound coming from ALL outputs of Korg Triton
try cleaning ALL the contacts involved with Caig DeOxit (D5, S5. F6, G5, etc.) products*, they work very well. e.g.; cables, inputs, outputs, and (if you're confident) all the contact points "under the hood". this static you speak of sounds like less than stellar contact points and can addressed at home if you've the motivation to DIY.
Mar 31, 2017 | Music
Tv picture and sound
Sometimes you just have to shoot the old girl.
Mar 13, 2009 | Televison & Video
Picture jumping
If this jumping is accompanied by a sharp snapping sound, it may be the high voltage circuit discharging to chassis. Leakage can cause the jumping and a discharge can momentarily blank the picture.
If you want to try a 'cleaning cure,' I suggest you pull the plug (not just turn it off) for several hours, preferably overnight. Sets of this size can carry enough static charge to punch a hole through your thumb if you get careless.
Remove the rear housing (shouldn't be more than 6-8 screws) and using a clean paintbrush, and possibly a vacuum to **** up the dust, clean it well and pay special attention to the area around a largish misshapen black plastic object bigger than most anything else and connected to the back of the picture tube via a fairly thick cable.
Dec 09, 2008 | Televison & Video
Intermittent "static surges"
Ionic Breeze is no longer supported because Sharper Image went into bankruptcy as a result of these products proving to be ineffective.
Here is a Sharper Image article
Here is an EPA article
Jun 17, 2008 | Sharper Image Professional Plus Ionic...
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black screen
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Hope ya fix it!
Mar 06, 2008 | Televison & Video
PLTV-32 GOOD PICTURE, Static Sound
If it is under warranty, you would be better off the return it for an exchange as the main board will need to be replaced. this board is not cheap. Good Luck
Mar 21, 2007 | Protron PLTV-32 Television
Zenith C36A26 36" TV Logo
118 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
