Question about Samsung DVD-V4600 DVD Player/VCR
Samsung V4600 HELP PLEASE!!
Okay I have hooked it up to the TV and the DVD is working great. I tried to install my Xbox360 into the 3 little cable plug things.. now how do I get to the XBOX360? I have the remote and everything
  • 905 Answers
You should be able to choose between video inputs like 1 , 2 input or if s-video is on the same input as another input like say the rca yellow video input then it won't work like that
Posted on Nov 27, 2008
Using your DVD-V4600, how do you play a vhs tape on TV? Need step by step instructions.
In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
  • You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
  • use either "RCA analog (red/white +yellow ) " or "SCART "or "Optic " cable.(any standard optical cable )...if exist ,optic is the best way to connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
  • pls also remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Samsung DVD-V4600 DVD Player/VCR
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
DVD's will no longer play
try blowing or its how you swipe your cds you should swipe up and down by a cd cleaner that might work
Apr 26, 2009 | Samsung DVD-V4600 DVD Player/VCR
Vcr/dvd won't play
You may have to buy an RF modulator ($20.00 at any radio shack or wall-mart) this will allow the hook up to work! ( has a channel 3 or 4 selector switch!)
I hope this is of big help!
Please rate answer
Thank You!
Jan 16, 2009 | Samsung DVD-V4600 DVD Player/VCR
No audio when using VCR/DVD player
the first thing that you need to do is use the video cables and audio cables that are on the back of the unit. This makes sure that you have sound and video.
Dec 22, 2008 | Sanyo DS27510 27" TV
Samsung DVD V9700
Double check the cables. if it has a tuner, use that
Nov 25, 2007 | Samsung DVD-V4600 DVD Player/VCR
Hook-up strategy
OK I will try to explain this...You need to go from your OUT TO TV output on your cable box and split that line so you have 2 lines coming out,then you can hook one to your vcr and one directly to your tv.Then you can watch tv while you are recording something on your VCR.I hope this helps
Sep 24, 2007 | Samsung DVD-V4600 DVD Player/VCR
Problems with Samsung model dvd-v4600
depends on the universal remote, please let us know which universal remote you have
Aug 14, 2007 | Samsung DVD-V4600 DVD Player/VCR
Turn off progressive scan without progressive tv?
This is not a solution but it is a big thank you to whoever posted the 3/20/07 solution to getting progressive scan OFF. I tried holding REW & FF in for 5 sec. and it worked. Thanks Again
Mar 20, 2007 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
93 people viewed this question
Henry  Thomas
Henry Thomas
