Question about Nu Mark AXIS 9
Pitch slider not working
I have the sxis 9 and the pitch slider is not working i think it has something to do with the key lock / key change and i dont no how to get it off please halp
    Problem Solver:
  • 7 Answers
Lol just select pitch and press plus or minus to the desired pitch range and if you want to take off key lock just press keylock till you dont see the keylock symbol.
Posted on Dec 19, 2008
Everything lights up but the screen is black and stays black
hi Friend your Problem is that your cellphone is not working properly all the functions are working but screen stays black.so it can be happend by 2 reasons.-1>i think you are using slider phone,so slider phones always uses a belt between screen and keypad some times, i think in your cellphone its not working properly you'll have to go any repairing shop and fix this problem with changing your belt..2>if you are not using slider phone then something wrong with your display ,means you'll have to change your display.
thnks , for further query feel free to ask ,i am always here for you.
Aug 14, 2011 | Cell Phones
I cant get my knobs or sliders on my oxygen 49 controller working keys, octave and mode and pitch work fine, its just the sliders and knobs
Here is a link that might help:http://www.m-audio.com/index.php?do=products.directlink If your DAW isn't supported it might have a learn function that might help. Make sure you download the latest update.
Oct 18, 2010 | M-Audio Oxygen 49 USB Midi Controller
Gemini CDJ02 - Pitch Control Slider Stuck @ 0% The Pitch Control Slider will pitch down all the way but sometimes it will randomly change pitch and most the time wont pitch-up past 0.1-0%. This happens on...
Your pitch control is faulty or dry. Try spraying wd 40 into the pitch sliding hole form top to bottom. Dont over spray it. Just a bit from top to bottom will do. If issue still persists, then there's some capacitors are weak which controls this pitch.
Jan 15, 2010 | Philips Gemini CDJ-20 Top Loading...
The pitch slider suddenly wont go bellow 0.00, for
i had a similar problem i used a can of compressed air and sprayed the dust out from pitch control and it worked. the dust builds up static and interferes with signal> hope it helps
Nov 30, 2009 | Pioneer CDJ-1000 CD Player
How come my axis 9 cd players pitch control moves on its own?
i take it u know to press key when changing the tempo? if u press key it changes the tempo but keeps the pitch the same. i keep that on all the time. if i want to change the pick i hold key and press either + or -
Mar 22, 2009 | Nu Mark Numark Axis9 Table Top CD Player...
Quartz accuracy not accurate
Sometimes it's down to the mains in the country you are in. Some decks change speed from 50HZ to 60HZ.
Dec 07, 2017 | Audio Players & Recorders
New Slider Does Not Work - key lock too!
I Would send the phone back, you could be damaging it even more.
Sep 21, 2008 | Samsung SGH-D600 Cellular Phone
Mp3 player says key locked system shut down
I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
Apr 30, 2008 | RCA OPAL M4001 MP3 Player
Pitch LED not working
LED probably burned out, or installed reverse (+/- reversed) - Or, you installed a clickless (MK3/MK5) pitch control in an MK2 turntable.
Did you do this yourself? Or did you have this professional done? If professionally, and the LED does not work, ask for your money back! This is electronics repair 101!
If you did this yourself, then more than likely you installed the LED backwards. The longer lead is the positive lead. If the LED did not burn out, you might be able to just remove it and switch it around. If it does not work, then it probably shorted (more than likely). Also make sure that none of your solder is touching. This could cause a bad short to your entire turntable. So you want to becareful.
If you need any further assistance, feel free to give our service dept a call. We are masters with the 1200s, and fix over 300 a year! 1.866.668.1596 ext 1
- TERMiNAL OPTiC
www.DJPROLAB.com
Feb 10, 2008 | Technics SL-1200 Turntable
Platter problem
THE PITCH slider or the variable resistor could have gone faulty. A new pitch is only $25 i think. They may need to salvage the pcb from your old one as technics no longer manufacters them. I've never seen the pitch led stay on lock when the actual pitch is not at zero. Hopefully the pitch did not short out the brake or the variable resistors on the motor's circuitboard.
keep me poted.
Oct 25, 2007 | Technics SL-1210 Turntable
Nu Mark AXIS 9 Logo
112 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
Marvin
Marvin
Morne Olivier
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
