Question about Brother HL-2040 Laser Printer
When I plug in my printer the power doesn't come on.
It used to work perfectly. Could the cord be faulty, or is it the printer?
    Problem Solver:
  • 18 Answers
I suggest that you try another cord but if that doesn't work i'd say that one of the board in the back of the machine may have become faulty which would stop your machine powering up.
Hope it works
Posted on Dec 09, 2008
The power went out on my lexmark printer...cannot get it on again, What are my options?
Try another known working power cord. If that doesn't work, it's most likely an internal issue with the printer. There's not much else you can do unless you feel comfortable opening up your printer and testing the power with a voltmeter.
Oct 19, 2012 | Lexmark X3350 All-In-One InkJet Printer
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
Screen on front lights up but cant see numbers are functions
Try to re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
If that doesn't help, try to plug the printer to a different known working power outlet in the wall to determine if it's a faulty power outlet issue.
If the problem continues, please contact Lexmark Technical Support Center for further assistance.
Nov 28, 2011 | Lexmark Prospect Pro205 Wireless...
My printer will power itself down and then power back up for unknown reasons?
It could be that your printer is not getting enough power to turn itself on properly. Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
If that doesn't help, try to insert your printer into a different known working power outlet in the wall. This will help us identify if it's a faulty power outlet issue.
Sep 15, 2011 | Lexmark C533DN InkJet Printer
I tried to send a fax but the machine turn on and off by it self and only the fax button keeps on, it makes the noise like if going to send the fax, but it turn off
It could be that the printer is not getting enough power. Pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will help reset the printer.
If that doesn't help, try to plug the printer into a different known working power outlet to verify that it's not a faulty power outlet issue.
Sep 09, 2011 | Lexmark X4270 All-In-One InkJet Printer
When you plug it in, (lexmark pro 205), there is a white light in the display box but no words or pictures and the on button does not light up. the only way to shut it off is by unpluging. It does...
Try to rebrick your printer. Pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will give enough time for the printer to reset itself.
You may also try to plug the printer to a different known working power outlet in the wall to identify if it's a faulty power outlet issue.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark Prospect Pro205 Wireless...
My Lexmark Z1420 wireless printer used to work perfectly; however, since we moved, I can't get it to work. We have wireless internet. I have reinstalled the driver. I have checked the cables. I...
Your printer may need to be reset. Disconnect your printer from your computer. Unload the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While the cover is open, check for any paper jams or obstructions in the paper path and the cartridge carrier's path. If all is clear, close the printer cover. Unplug and re-plug the printer into the power source to reset it.
When the printer turns on, reinsert one cartridge first. Close the cover. Check for any errors. If no error, reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to reinsert a different known working cartridge to determine if the other is faulty.
For your wireless connection problem, you may need to reset the printer's wireless network settings first. Please refer to How to Reset the Z1400 and Z1500 Series Network Settings.
To reconnect the printer to your wireless network, re-launch Lexmark Wireless Setup Utility on your computer.
Jun 21, 2011 | Lexmark Z1420 InkJet Photo Printer
Pump motor stalled
Hi victor_orell,
The Pump stalled error it is often caused by the ink system has failed. To correct this error please follow the steps below.
1. Power drain. Please unplug the power cord at the back of the printer. Press and hold down the power key for 30 seconds then release the key and plug the power cord back in.
--> if this doesn't work please proceed to the next step.
2. Partial Reset. Please unplug the power cord at the back of the printer.Press and hold the # and 3 keys together and while holding them plug the power cord back in. Check if the problem is resolved.
If Not
3. Semifull reset: Unplug the power cord from the back of the printer again. Press and hold the # and 6 keys together and while holding them plug the power cord back in.
4. If you're still encountering the same error, please remove all the print cartridges (with the system powered up). Clean the copper contacts with the help of a lint free cloth then reinstalled them. Allow the printer to go through its normal sequence then go to the Setup, select tools, then clean print head.
Hope it helps.
Thank you for using FixYa.
May 02, 2011 | HP Photosmart C6180 All-In-One InkJet...
Failure Oxc05d0082
Hi eherndl,
The failure Oxc05d0082 description is a pump stalled error, it is often caused by the ink system has failed. To correct this error please follow the steps below.
If Not
Hope it helps.
May 01, 2011 | HP Photosmart C6180 All-In-One InkJet...
Stopped working...is it a fuse wrapped around the power cord that could be faulty?
no that is a graphite ferrol just to cut down noise it may receive from other devices. check the voltage with a meter on the power supply. If it plugs direct into a/c from the wall, the power board is most likely bad in printer. then it's a throw away.
Oct 22, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Brother HL-2040 Laser Printer Logo
20 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
