Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Sir, I have tried what you have suggested for catastrophic failure
When I have register using regsvr32 jdboledb it has given the following message ' JDBOLEDB was loaded but the Call to Dllregisterserver failed with error code 0x8000ffff'
Kindly help me to move further.
    Sergeant:
    Champion:
  • 274 Answers
That is a critical error. Something is not allowing you to access your registry. You might not have security to do so.
You might have to log in to your computer as administrator.
I recommend you contacting PeopleSoft support and make sure your system meets their specifications.
There might be a version difference maybe Vista 32 vs. 64.
Posted on Nov 27, 2008
When i am opening it, it is showing the program cannot start because loader.dll is missing from your computer try reinstalling it
Microsoft is constantly updating and improving Windows system files that could be associated with Loader.dll, sometimes resolving your DLL problems may be as simple as updating Windows with the latest Service Pack or other patch that Microsoft releases on an daily basis.
To help you install Windows update, please follow the steps given below:
- Steps used in (Windows XP, Vista, 7, 8, and 10).
- Click the Start button.
- Type 'Windows Update' into the search box and select it.
- The Windows Update dialog box will appear, if updates are available, click on 'Install Updates' button.
- After installing Windows Update, it is recommended to restart your computer once and then try using the computer.
If issue persists, you can use a built-in utility called 'Microsoft Register Server' (regsvr32.exe) to re-register your Loader.dll file.
In some cases your DLL file may not register properly and so you may get the error. To help you register Loder.dll file, please follow the steps given below:
- Type 'command' in the search box... DO NOT hit ENTER yet!
- While holding 'CTRL + Shift' on your keyboard, hit ENTER.
- You will be prompted with a permission dialog box and click Yes.
- Type the following command: regsvr32 /u Loader.dll and hit ENTER, this will UN-REGISTER your file.
- Now type the following command: regsvr32 /i Loader.dll and hit ENTER, this will RE-REGISTER your file.
- Close the command prompt window and restart the computer once again to check if the problem is fixed.
GuruAid.com
May 13, 2016 | Computers & Internet
How do i register on 2go?
You can use the Regsvr32 tool (Regsvr32.exe) to register and unregister object linking and embedding (OLE) controls such as dynamic-link library (DLL) or ActiveX Controls (OCX) files that are self-registerable. This may be necessary to troubleshoot some issues with Windows, Microsoft Internet Explorer, or other programs. It is also frequently used by program hacks.
1.) Copy the files you would like to register to [C:\WINDOWS\system32]
2.) Go to the command prompt Start --> Run --> cmd
3a.) To install/register the file type in: regsvr32 file.dll or regsvr32 file.ax
3b.) To uninstall the files type: regsvr32 -u file.dll or regsvr32 -u file.ax
4.) Some type of message should be displayed that says you successfully registered or unregistered the file
May 11, 2011 | Computers & Internet
What does 0x800ffff mean
KB1001.800
Problem: GWXMail error 0x800FFFF (or other) using REGSVR32
This article applies to GWXmail
Problem
    When you run regsvr32 with GWXMail to register it, you may get error 0x800FFFF or a generic message saying the registration failed.
Details
    Microsoft's REGSVR32.EXE program is used to register all Active X server components. If you don't have the most recent version of regsvr32.exe, or don't have all the correct support files to go with it, you may not be able to register your Active X component.
Solution
    Search your hard drive to make sure you only have one copy of regsvr32.exe. If you have more than one, delete all but the most recent. Check Microsoft's site for a newer regsvr32.exe, especially if you are not using IIS 4.x, or haven't applied the IIS 4.x service pack.
    Make sure you have version 05.00.4319(SP2) of MSVBVM50.DLL on your system. If you need this file, you may download it from here or from Microsoft.
Feb 13, 2011 | Computers & Internet
After I installed Internet Explorer 8 I Have to sign in on every web site I go to,some times I stay signed in for 1 day,some times 3 days,now when I log out on any site it will close every thing including...
Step 1: You can reset the internet settings to default and check. You can go through the following link:
http://windows.microsoft.com/en-GB/windows-vista/Reset-Internet-Explorer-8-settings
Step 2: You can also try to re-register the dll files associated with IE8.
To re-register the Internet Explorer .dll files. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type cmd, and then click OK.
  3. At the command prompt, type the following lines, and then press ENTER after each line: regsvr32 softpub.dll
    regsvr32 wintrust.dll
    regsvr32 initpki.dll
    regsvr32 dssenh.dll
    regsvr32 rsaenh.dll
    regsvr32 gpkcsp.dll
    regsvr32 sccbase.dll
    regsvr32 slbcsp.dll
    regsvr32 cryptdlg.dll
  4. Click OK when you receive the message that DllRegisterServer in FileName succeeded.
  5. Type exit.
-Reboot the computer and check how it is working.
Dec 24, 2010 | Microsoft Internet Explorer 8
I can't connect to the windows update site. When I click on windows update it either goes to the page that says Internet Explorer cannot display the webpage, the MSN homepage or some random search page. I...
Hello Sir,
Try typing these commands and check whether you could access the update page
Commands
Re-register the Windows Update DLL with the commands below
1.)Click Start, click Run, type cmd, and then click OK.
Type the following commands. Press ENTER after each command.
regsvr32 wuapi.dll
regsvr32 wuaueng.dll
regsvr32 wuaueng1.dll
regsvr32 wucltui.dll
regsvr32 wups.dll
regsvr32 wups2.dll
regsvr32 wuweb.dll
Aug 12, 2010 | Toshiba Satellite M35X-S109 Notebook
Cannot access Email accounts from Internet Explorer. Get HTTPS: Error 12169. I can access Email accounts with Firefox. Also, uninstalled IE8 and went back to IE7 but that didn't help. Downloaded new...
Basically I found an article at Microsoft's site entitled "How to troubleshoot situations where you cannot complete MSN sign-up or connect to SSL secured (128-Bit) Web sites by using Internet Explorer in Windows XP"
To make a very long story short ... all you have to do is re-register the following .dll files:
Softpub.dll
Wintrust.dll
Initpki.dll
Dssenh.dll
Rsaenh.dll
Gpkcsp.dll
Sccbase.dll
Slbcsp.dll
Cryptdlg.dll
To re-register these files, follow these steps:
2. In the Open box, type one of the following commands, and then click OK (copy and paste is your best friend):
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 slbcsp.dll
4. Click OK when you receive the message that says DllRegisterServer in FileName succeeded.
5. Repeat for each command line listed above
Mar 04, 2010 | Toshiba Satellite A35-S1592 Notebook
CANNOT update my windows and microsoft
check this link for more info
Thanks Good Luck
Appreciate to rate as "Fixya"
May 03, 2009 | Computers & Internet
Problem with accessing and sending mail from yahoo account
Re-register the following .dll files:
Softpub.dll
Wintrust.dll
Initpki.dll
Dssenh.dll
Rsaenh.dll
Gpkcsp.dll
Sccbase.dll
Slbcsp.dll
Cryptdlg.dll
1.
2.
In the Open box, type cmd , and then click OK.
3.
At the command prompt, type the following lines and press ENTER after each line:
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 slbcsp.dll
4.
5.
Type exit .
Mar 23, 2009 | Microsoft Windows Vista Business Edition...
Catastrophic failure reported by operating system - Vista home pr
Try this..
START button > RUN
Type in or Copy/Paste from here into the command line...
REGSVR32 JDBOLEDB.DLL
This will try to register it. If no error messages pop up it's been added.
To unregister it do... /u
REGSVR32 /U JDBOLEDB.DLL
Nov 24, 2008 | Microsoft Windows Vista Home Premium with...
Problem w/ WIN2000 Pro & XP Pro
HERE IS THE SOLUTION :
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
188 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
