Question about HP Vs17 17" LCD Flat Panel Monitor
Monitor keeps giving error msg,, no input - HP Vs17 17" LCD Flat Panel Monitor
  • 849 Answers
This not your monitor problem, check your computer.
Posted on Nov 27, 2008
Not restore
verify if you are inputting the correct password.If you are sure and still it gives the same error msg,thn consult a technician.
May 23, 2014 | Nokia Classic 2700 Cell Phone
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
My acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msg are shown but once Windows starts, this error appears. I have tried to adjust the...
May I ask to what you mean by "adjust the resolution in safe mode, this has not helped"?
Did you set it to native resolution of this monitor? Unless it has problem inside the monitor, try it with another PC also.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 08, 2010 | Acer AL1916W 19" LCD Monitor
Our acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msgs are shown but once Windows XP starts, this error appears
Your resolution is set above what the monitor supports.
when computer is first starting up hit f8 to get to boot modes.
choose Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
When you are booted into windows you can then set your resolution to the highest that the monitor supports which is 1440x900
Let me know if this helps.
Mar 16, 2010 | Acer AL1916W 19" LCD Monitor
Monitor going to sleep
turn off the hibernation mode if it is turned on.
Jun 15, 2009 | Dell Dimension 3000 PC Desktop
Black pic on tv fm dvd rec
Several possibilities. If there is a HD box going into this unit, it will give you this message. If there is a modulator or converter box between the cable/sat box and this unit, it will give you that msg. If you have an input plugged into an input, it will give you this msg. Finally, if you have anything other than a camcorder plugged into the FRONT of this unit, it will give you this message. Recheck your connections.
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
MONITOR FREEZE
Hi
You need to hold down the monitor menu button and you will get the msg on the monitor tht the OSD menu is unlocked....
It will take about 10-15 seconds....
Feb 25, 2008 | Gateway FPD2275W LCD Monitor
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
