Question about Philips MMS 460 - PC multimedia home theatre speaker system - 80 Watt (Total) System
Hi. I have had a Philips MMS 460 5.1 surround sound system for about a year already. However, its been plugged and unplugged from my computer to my ipod in various times. However, there is no power now and i do not know why. I have even replaced the adapter with another one of the same output and input thinking it might be the adapter but it still does not work and i do not know why. Any help would be nice. thanks
  • 905 Answers
There is most likely an internal problem then and it would need to be tested to see what has exactly happened to it
if you cannot work on this then taking it in to a repair shop or seeing what phillips can do for you would be a couple of options
electech
Posted on Nov 27, 2008
  • jason Nov 27, 2008
    sorry you can't except the truth
When I connect me ipad to the Philips mx5500D the sound is low
maybe your ipad's volume is low - volume settings for ipads are different when both plugged / unplugged
Oct 27, 2012 | Philips MX5500D System
Hello, i have phillips 460 5.1 speakers.. the sub is buzzing/humming REALLY loud.. it does it every now and again.. will start of quiet, then gradually get louder. they are a few years old now,...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
May 31, 2011 | Philips MMS 460 Computer Speakers
Philips 5.1 multymedia speaker how to connect pc
You may buy an external USB sound card with 5.1 channels
Sep 13, 2010 | Philips MMS 460 - PC multimedia home...
Philips HTS3400 home theater
possible jammed mechanism, or motor issue
Feb 01, 2009 | Philips MMS 460 - PC multimedia home...
I need Philips DSS 350 Computer Speakers driver win xp
well if it is just a download you need go to google and jut type what driver you need that should do it
Feb 08, 2008 | Philips MMS 460 Computer Speakers
Philips mms460 5.1 surround sound speakers
Its better to change your probes because it has been get damaged...
thankyou...
Jan 02, 2008 | Philips MMS 460 Computer Speakers
Philips MMS 460 Computer subwoofer problem
Found it.....
Replaced the 1.5Amp 12v Reg with a 3Amp 12v and heatsink...also replace all the electrolitics in the same area. Reasoning being gone leaky due to hot heasink.
Remember to Silicon the heatsink down afterwards as it rattles if you dont!!!!
Oct 07, 2007 | Philips MMS 460 Computer Speakers
No sound
Most computers use the GREEN output jack on the sound card for playback...plug your headphones in the back where the speakers go...sound? Yes...then verify you ahve the speaker system put together correctly...bet you don't...note: self powered speakers must be plugged in to work (electrical plugged in). If no...then you got a bigger fish to fry... Good lUck
Aug 26, 2007 | Philips MMS 460 Computer Speakers
Philips MMS 460 - PC multimedia home theatre speaker system - 80 Watt (Total) System Logo
199 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
