Question about Ricoh Aficio G7500 Printer
Network printing problem
We've just unpacked our new printer and set it up; the computers in the office are Macs but the network is PC. We can't install the driver here/locally because it won't translate Mac. Any ideas? help?
SOURCE: No PPD available for mac
I used the Gutenprint driver for the Ricoh 220. It seems to be working fine.
Posted on Nov 14, 2008
SOURCE: Mac OSX 10.4.11 won't print to Ricoh Aficio CL2000n network printer
As an update:
I actually had a Ricoh tech come out to my house. It was a warranty service - I was very impressed! He did some fiddling around, said that there was no problem that he could detect but... after he left the Macs can print to the printer no problem. From what I can recall, all of the settings were identical to what they were in the first place on the Mac side.
I still can't get my linux machine to print there but it is a low priority and I am really not trying very hard.
I wish I had more enlightening input.
Posted on Nov 24, 2008
use an updated driver version for this machine on, another solution is using pcl5 driver as this one does spooling at computer and not machine...
Posted on Mar 09, 2009
SOURCE: Need help setting up printer on a network
Set a compatible IP address on machine:
"user tools"
"system settings"
"interface settings"
"IP address" (set compatible number)
"subnet mask" (set the right one)
Download driver if it's not done already, create the matching tcp/ip port, and continue with installation. Select "share this printer".
Driver is here if you need it:
Posted on Apr 16, 2009
SOURCE: Ricoh Adicio on a mac
You'll need to download and Install the "PPD" installer for your Mac OSx here, if you haven't already done so:
..... then (assuming that your Copier doesn't have Postscript installed - most don't) browse for the printer, but be sure to select the driver version that points to "pxl", and not a "ps", or "pcl" driver. "PXL" is the only language that will work with Mac if postscript is not installed on the machine.
Good Luck. Please rate me.
Posted on Jul 22, 2009
SOURCE: Hi, I have an RICOH Aficio
Hi there. When you installed the drivers locally to each computer, you should be given the option to select the device as the default printer. I understand that you have not chosen this during your installation process. The best options would be to either install this driver on the server and/or use a logon script to set as the user's default printer upon each log on to their computers.
Posted on Jan 17, 2011
0 characters
1 Points
Can not print with canon mx 870 using a ipad
The airprint system is not yet compatible with all printers. Were you told that you could print to this printer from your iPad?
There is a piece of software for Macs that allows any printer to print from an iPad or iPhone 4 called Printopia 2. I've been using it to print to an Epson A3 printer and a Canon A4.
Apr 29, 2011 | Canon PIXMA MX870 Wireless Office...
How can I get my Windows PC to see my printer(s) on my Mac OS X network?
I am sure this question has arisen more than once, as to just how to locate and use the network printer in your Mac OS X network,so you can print from your Windows PC. After all, the Macs you have in your network print with no problem, why not the PC?
But nothing seems to work, that you have tried. So what to do?
Well, the answer comes with a simple yet very effective technology implemented by Apple Inc., just to address this issue.
It is a zero configuration networking protocol known as Bonjour.
Bonjour formerly known as Rendevous, was implemented from the Zeroconf (Zero-configuration) service delivery protocol and first introduced by Apple in its software with the release of the Mac OS X 10.2 Jaguar system.
In lay terms, what "Zero Configuration Networking" means to you, is that you do not have to be computer geek or guru, to simply install or configure this software, because it was designed for the most part to automatically discover computers, devices, and services on local IP networks.
The "local IP network" being described here, is your own network, whether it is in your home, home office or anywhere you have a network setup.
What makes Bonjour so efficient, is that it can work with PCs in order to work with devices connected to Macs. To use it, all you need to do is install the software to your PC. Macs with Mac OS X versions from 10.2 to 10.6, of course, already have Bonjour as a built in feature.
So how do I use Bonjour to discover printers on my Windows PC(s)?
It really is a simple as 1 -2-3.
1.) Download Bonjour - You can simply search for it by name through
Google or your favorite web search engine, or
click the link below to install in on your PC.
Download and Install Bonjour for Windows
2.) Install Bonjour - Simple enough, install it once the download is
complete. In the example below, I use my Epson
NX415 printer as a network printer on a Mac OS X
network, that needs to be discovered by a Toshiba
Laptop with Windows Vista Sp2 also a part of that
3.) Launch Bonjour to discover the printer(s) in your network -
a.) Introduction Screen:
You will be very satisfied when you see how little
effort you have to put into discovering the network
printer on your PC with the Bonjour Printer Wizard.
**Note: Keep in mind, the network printer must be properly
connected, turned on and functional, otherwise Bonjour
will not discover your networked printer with your PC.**
b.) Printer Discovered:
Printer in Mac OS X network, if working and turned
on... Should be discovered by Bonjour right away..
c.) Printer Driver not needed:
A really nice feature with Bonjour:
You really don't need to have the print driver software for the
discovered printer. Bonjour will identify the printer, its
location on the Mac OS X network and will use a
Generic/Postscript identity due to a print driver for the
PC not being needed.
d.) Summary of discovered network printer:
Final screen for the Bonjour Printer Wizard. Just click
the Finish button and that is all it should take.
Now open any document run a test print..
on and get to printing with the newly discovered
Mac OS X network printer on your PC.
Now, that you know, no more guessing, on how to find
that elusive Mac OS X network printer for your PC.
Happy Printing!
on Feb 04, 2010 | Printers & Copiers
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Printers & Copiers
Trying to connect 4 MACs to all in one Kodak 5250 printer and will not connect via wireless. I had to set up so that the other pc's have to print from one location via hardwire. I tried installing...
If you have one PC connected to the printer via USB you can share the printer to your Mac computers easily:
If the printer is connected to a Macintosh computer via USB:
1) Open System Preferences
2) Click on Print and Fax
3) Highlight the Printer and Check the box Marked "Share This Printer On The Network"
If the printer is connected to a windows computer via USB:
1) Download "Bonjour Print Services for Windows" from Apple's website
2) Install it on the PC connected to the Printer.
3) After Installing the Above, Run the Bonjour Printer Configuration Utility and select the Printer you want to share and it will share it over the network to all your apple devices.
Mar 02, 2011 | Kodak ESP5250 All-In-One InkJet Printer
We have four computers, 3 Macs and a PC networked via an Apple Time Machine to a Hewlett-Packard HP Color LaserJet CM1312nfi MFP. All of the Macs display "Looking for Hewlett-Packard HP Color...
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Nov 23, 2010 | HP Printers & Copiers
Xerox Phaser 8560DP shows annoying 'print completion' message
Someone installed the "Printing Scout" on this computer. You may need to uninstall or check all the settings in the printer driver. I'm not really familiar with Macs but I know the 8560 inside out, upside down, and backwards.
Jun 08, 2009 | Xerox Phaser 8560DN Laser Printer
Can't print from my local printer with Remote Desktop
Try the following :
1. Go to Printers and Faxes
Right click on the printer u are using. Select Share this printer.
2. Set up a home or small office network with Internet connection connected, Printers on on both computers and identify both of them saperately.
For this you need to connect both computers with a cross cable.
3. after the home or small office setup is complete add a new printer from your Printer and Faxes menu. Search your printer automatically and choose it from the llist system provides and select the printer as default if needed.
4. Try taking a 'Test Printout' from the Concerned printer's properties page.
5. if this works, you have successfully installed the printer and are ready to take prints.
Mar 29, 2009 | Sharp AL-1642CS Copier
Network or Share HP LaserJet 2200D Printer
Try this:
1. Go to the computer where the printer is attached or connected. Go to Printer and Faxes under XP, right click on your printer icon, then click on share. On the same computer, click on Start then click on run. Type in cmd then click on OK. On the black window or command prompt, type in ipconfig then press enter. Take note of the IP address.
2. Go to a computer that you want to print on the printer. Click on start then click on run. type in \\IP address of the computer where the printer is attached. For example: On the run box type in \\ the click on OK. You will see there a window and you can see there the printer that is attached to that computer. Just right click on it then click on Connect.
3. Try to print.
Hope it helps!
Oct 21, 2008 | HP LaserJet 2200D Printer
Canon MX700 network problems
Once you have it installed and working on the USB port go to the properties page of the printer.
1) Select the "Ports" tab.
2) Select "Add Port".
3) Select "Canon BJNP Port".
4) Select "New Port".
5) Fill in the IP Address of your printer and select "Next".
Make sure that the Port is checked back in the properties page and select "Apply" and your done. Do a test print and your printer should work on your network. You may still need to fix the settings on your firewall or router to allow access if it does not print.
Sep 04, 2008 | Canon MX700 Office All-In-One InkJet...
Printers & Copiers Logo
21 people viewed this question
Top Ricoh Printers & Copiers Experts
Bernard D'Souza
Are you a Ricoh Printer and Copier Expert? Answer questions, earn points and help others
