Question about Bose Acoustimass 15 System
Bose Lifestyle 35 Accoustimass module rattles at high volume
Today my friends Accoustimass module tipped over and hit the wood floor pretty hard when we were hooking it up in his new house. When we finally got everything connected and turned it all on, we put in a DVD that had a THX sound demo at the beginning. When the bass tried to max out the sub starting crackling and breaking up. We had the volume at around 85 at that time. When we reduced it to 75 it hardly breaks up. But it seems to me it shouldn't even at the higher volume. Is it possible something got damaged when it fell over on the floor? Or is it likely that you can't run it at a volume of 85? He's had it for several years and had it in an apartment and probably hasn't typically had it over a 65 volume setting. It was my fault it fell over and I'm trying to determine if it broke today or if it's probably always been that way and he didn't know it.
  • j_r_l Dec 16, 2008
    In case anyone reads this and wants to know:
    I called Bose to see if the level should be able to run at 85. They said it is designed to run at 100. But if the base is turned up really high there is a possibility it could distort. But the guy I talked to said he had about the same system and his could run at 100 with absolutely no disortion at all.
    THEN...THE BIG NEWS! That model (which is actually the Lifestyle 28 from 2001, not the Lifestyle 35) can be completely refurbished by BOSE for $165, you pay the shipping there, and they pay it back. It also comes back from Bose with a 1 yr warrantly like a new system. They will check all electronics and functionality of the Media Center and Acoustimass module and repair anything that is not working 100% perfectly.
    My opinion is that is a great deal. Since BOSE systems are SO expensive, it does't make sense to try to find a used replacement Acoustimass module or Media Center. So my friend shipped his back to Bose for repair. When he called to set up the repair, he found that Bose will ship you, free of charge, a box with styrofoam packing to fit your system for shipping to them. He als had the guy on the phone listen and he verified that he suspected something was damaged in the Acoustimass Module.
    The price for repair does vary depending on your Bose model. But it's worth a call to find out even if you don't expect you have any issues... well... maybe.
    Problem Solver:
  • 20 Answers
Well to be hones 85 sounds pretty loud to me, generally the bose acoustimass module shouldnt really be distorting or crackling unless under extremely high sound levels.
It could possibley be that the speaker cone in the bass module has a slight perforation so it would distort at high levels. However other problems could be loose connections inside the unt or outside the unit. If your friend doesnt have it above 85 under normal circumstances I wouldnt worry to much about it but if there is a tear in the cone the problem could get worse.
Posted on Nov 27, 2008
How do you open the cover to bose accoustimass
Bose Acoustimass is a bandpass cabinet. Needs to be sealed. I recommend to send it to a service center.
Nov 21, 2013 | Bose Lifestyle 12 System
Bose lifestyle 48 won't play stored music. Everything else works fine
Hard drive is ****..... impact computers.com hard drive number is MK4026GAX pull out of system and replace look at my other posting for 801 code!!! and dont be a ******** again and buy a bose!! TELL YOUR FRIENDS , FRIENDS DONT LET FRIENDS BUY BOSE!!!!
Mar 19, 2010 | Bose Lifestyle 48 System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
My bose lifestyle 35 system does not play divx dvd. I do i enable divx dvd.
DivX compatibility is not a feature of the Lifestyle 35 system. You can contact Bose Support, to inquire as to whether they have any firmware upgrade for DivX compatibility. To the best of my knowledge, there is no such upgrade in existence for the LS35.
Oct 16, 2009 | Bose Lifestyle 35 System - black Theater...
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
May 31, 2009 | Bose Lifestyle 35 Series II System
Picture on my Bose Lifestyle 35 is jumping around
Hi
Replied you on premium post as well.
Please change TV color system to AUTO to see jumping free picture.
If Bose is either on PAL or NTSC color system, TV will show correct picture and color automatically.
Feb 08, 2009 | Bose Lifestyle 35 System
Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
Sep 17, 2008 | Bose Acoustimass 16 Speaker
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
Bose lifestyle 20 static
if you have turned the speakers to a high volume you have to tighten all the screws and bonds that should help
Oct 14, 2007 | Bose Lifestyle 20 System
Bose Acoustimass 15 System Logo
477 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
