Question about Sony Handycam DCR-HC40E Mini DV Digital Camcorder
Sony dcr-hc40e My camera will not toggle between playback and record. Most of the time when I try to record using the record start stop button it toggles between playback etc. (the things that should be controlled by the side mode toggle). Sometimes the mode toggle will not toggle or even turn off. The memory stick duo light flashes when charging, but the charging light does not. In short it seems to have a mind of its own which is a pain as I have a 2 month old daughter I'd like to video! I have tried a fresh battery as that is all I think I can sensibly do without wrecking the camera. Any suggestions much appreciated.
5 Suggested Answers
  • 14 Answers
SOURCE: Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
Posted on Nov 14, 2008
  • 107 Answers
SOURCE: Sony Handycam Dig 8 doesn't recognize tape when trying to record
If it has memory stick, Make sure your memory stick is in. Your memory stick is full. Delete the unwanted pictures from the memory stick or use a differnt biger memory stick.
I looked in the manual. It seems your camcorder does not have a slot for memory stick. But you may still save pictures on the tape. Here is the link to download the manual
http://www.docs.sony.com/release/DCRTRV140.pdf
Please read Page 40 "recording picture on the tape".
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 24, 2009
larry james
  • 287 Answers
SOURCE: What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
Posted on Apr 26, 2010
welcomejee
  • 10594 Answers
SOURCE: the toggle button on my sony dcr-dvd301 doesn't
If you are handy with electronics stuff repair and can take apart camcorder then can replace toggle switch in Sony DCR-DVD103 camcorder, it is mounted on JS-031 board, its small circuit board that is easy to get replaced by taking off side cabinet. JS-031 board part number is as follows:
A1070102A ..... JS-031 BOARD, COMPLETE
Available in PartStore.com for $37
Hope these info will help you.
Thanks.
Posted on Nov 18, 2010
While capturing video from sony DCR-HC 40E via pinnacle 14 HD through IEEE 1394 in wondows 7, the captured video showed too many frame drops.
Sounds like time code breaks.
If you stripe the tape (record in one continuous run with the lens cap on and audio off) this will assist greatly.
Feb 17, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
The touch screen on my Sony DCR-HC40E is not working
Hi!
The flat LCD cable which goes through the hinges has broken - a common problem with many Sony camcorders. You will have to give it to Sony for repair.
I work for Sony.
Tom
Oct 09, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
My Sony DCR-HC40E has a fault with the touch screen. The touch screen is not displayed so I am unable to play/edit or even record/view anything. The screen is usable if you know where the controls are...
Hi!
I work for Sony.
Tom
Grey lines
I have had this problem myself, and it is nothing more than a head cleaning issue, from my experience. Sometimes, when a head cleaner will not work, the camera requires proper maintenance. The problem arises through long pauses, and over time. A suggestion for better use perhaps, would be to not pause tape for too long when playing back. Based on personal experiences.
Jul 04, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
My Camcorder is in full power and I can see what I am trying to video . . . but nothing is happenning when I click the record button. I have a SONY DCR-DVD100 NTSC and am using a Sony DVD-RW DVD (1.4 GB).
Let me know do you see correct picture in playback of previously recorded disc?
If yes, Then camera has ccd imager problem and that part needs to be replaced.
Let me know about playback question to help you more.
Jan 10, 2009 | Sony Handycam DCR-DVD100 DVD Camcorder
Sony DCR-HC40E Tape Holder Mechanism load failure
Your camera needs Mechanism replacement.
Software CD is available on charge basis.
Apr 30, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony Handicam DCR-HC40E not getting recognised by Vista
Hello
I found a solution installing the generic Sony USB driver in Vista Ultimate using compatibility mode (Windows XP SP2).
Mar 12, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony Handycam DCR-HC40E Mini DV Digital Camcorder Logo
65 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
