Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Emachine T3624 NIC Problem
XP will not find and configure on board ethernet NIC. I bought a new PCI NIC. How do I disable onboard NIC?
  • 2,794 Answers
Shut the computer off at the beginning of the bootup process look for the function key or keyboard button to get into the bios setup. Press that button and look in the settings to disable the onboard network adaptor.
Posted on Nov 27, 2008
Inside my emachine desktop pc where do I find the network interface card? I need to replace it since an electrical storm destroyed it.
The NIC (network interface card) resembles a telephone jack only larger. It's where your ethernet cable goes. On some E-machines, the NIC is onboard meaning it's permanently attached to the motherboard. If this is the case, it's still possible to install a different NIC in 1 of the blank PCI slots. Remember to Disable the existing NIC in your device manager to avoid any possible conflict.
Aug 31, 2011 | E-Machines eMachines Desktop PC
I have an emachines t3256 desktop that i just reinstalled windows xp and now i cant get the network adapter to work its onboard and i cant find a driver on their website
Try installing a PCI ehternet card.Turn off the cpu then restart.The cpu will automatically (!?)detect the new hardware and even install the driver(generic).Then there you can get to the internet and get you E-machine drivers.It will also install the driver for your onboard ethernet(NIC) adapter and with that you are good to go.
Dec 04, 2010 | E-Machines eMachines Desktop PC
The on board ethernet adapters were damaged so i purchased an ethernet card Realtek 10/100/1000 however it gives me internet for all of 30 seconds until i try to access a website then it dies and loses...
There shouldn't be any issues if the network connection worked with the integrated NIC. Maybe you just managed to purchase a defective replacement card. The other possibility is that you didn't disable the onboard network hardware in the computer BIOS settings. There may be some conflicts since the motherboard is trying to address both of them. Make sure the onboard NIC is disabled, and try another PCI card if you still have problems.
Apr 14, 2010 | ASUS A8N-SLI Premium Motherboard
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
Pc powers up but no video on screen gateway 420gr desktop
Yes generally speaking when you drop in a videocard it typically will disable the built on one. You may have to disable it though. I know you said you did not see the onboard video in BIOS but there is almost always a setting in there to turn it off.
Sep 17, 2009 | Dell Dimension 8200 PC Desktop
Onboard VGA port disabled, in Vista
You should try to disable it in the hardware list.
E-machines have an odd bios where not all the functions of the motherboard are available to the user.
If you can find the make and model of your board there is a good chance you can find the PROPER bios for it.
Emachines use motherboards from a variety of regular motherboard suppliers
My older e-machine has a hacked bios so that I can alter ALL the settings.
Aug 24, 2009 | eMachines EL1210-11 PC Desktop
Have T3624 need drivers for nic card
Try going to eMachines driver support page and see if you can download the drivers for your system.
ALSO TRY:
Here are the drivers for emachines t3624 ethernet: http://downloadfinder.intel.com/scri...nm=PL2KXPM.EXE
Jul 12, 2009 | E-Machines Computers & Internet
Emachines T3624 Ethernet controler
well, if you have a built-in NIC card, usually you should have a CD that has the driver for you ethernet controller.
or you might want to visit the link below to download your driver
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3624
I think the one you need is that Intel 845GV Chipset Driver
Mar 25, 2009 | E-Machines eMachines Desktop PC
Ibm netvista 2257-32u
First off I would troubleshoot the NIC onboard, but if it is not working then you should have an available PCI slot to install a new NIC. However you will also have to disable the onboard NIC in the BIOS.
If you are using windows
Click --Start --run-- type in cmd and hit <enter> (this will bring up the dos box)
then type ipconfig /all
It should come back and show:
Connetion-specific DNS Suffix : xxxxx.xxxx.com
Description: Brand and type of NIC
Physical Address : xx-xx-xx-xx-xx-xx
DHCP Enabled: yes or no
AutoConfiguration Enabled: yes or no
IP Address: xxx.xxx.xxx.xxx
Subnet mask: xxx.xxx.xxx.xxx
Lease Obtained: date when it connected
Lease Expires: date when connection expires
Default Gateway: xxx.xxx.xxx.xxx
DHCP Servers: xxx.xxx.xxx.xxx
DNS Servers: xxx.xxx.xxx.xxx
If all this is showing correct then try typing ping 127.0.0.1 this will be the NIC itself and it should reply back. If not then do the following.
If it does not show up then check device manager and see if the NIC is disabled.
if it is disabled try reenabling it.
if it is not unistall the device and then reboot the PC it should find the NIC and install it.
if all this fails then replace the NIC
Oct 30, 2008 | IBM Computers & Internet
Computers & Internet Logo
241 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
