Question about Brother DCP 7010 Multifunction Laser Copier
Paper jam i have a Canon MF 4150. th problem is paper always jam oftenly. please help me out.
  • 313 Answers
If the paper is jamming coming out of the tray try taking the paper tray out and look where the feed rolller is located if you get a soft cloth and some form of cleaner like windowlene or glass cleaner rub the feed roller or tyres they might have gotten dirty..also check the paper path from the tray and see where hthe jam occurs you should be able to see if there is a sensor arm stuck,, if the jam occurs near the exit also check when the paper comes out if it is curling this shows the p[aper has picked up some damp.. try with new paper or put your paper near a radiator to dry out for a while and try again. if it hjams near the fusing section ie... the hot area with the rollers where the paper passes through there are guides there that might have been knocked out of place you may also see a build up of toner on these.. becareful it is hot here so wait before you stick yer fingers here.. goood luck A
Posted on Jun 12, 2009
I own a Canon Image Class MF 4550 d. This morning
Try turning the printer off and back on. If this does not work, try rebooting your computer. Another choice is to go to the Control Panel > Programs > Unistall a Program and delete the printer's software, reboot your computer and re-install the printer's softwre.
If this does not work, you can always return your printer for a full refund or ask them to exchange it for a new one.
Sep 07, 2013 | Canon I-Sensys Mf4550d All-In-One Laser...
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I had a major paper jam at my printer (Canon, Super G3, imageClass MF 4150). I removed all the paper which was not easy. The printer is not working and switches to following messages: Paper Jam, Lift panel...
  1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  2. Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  3. Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  4. Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  5. Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  6. Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  7. Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  8. Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Jan 26, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Our XEROX Worcentre 4150 often jams and displays a
In the main door at the top in the middle there is a little black leaver that moves up and down if it gets stuck in the up position it thinks that there is a papper jam just check the little black lever and make sure its down
Jul 09, 2009 | Xerox WorkCentre 4150 All-In-One Laser...
No display in canon imageclass MF 4150 can any one
if you are a technician you repear your copier power supply board chack your power supply board fuse
Jun 28, 2009 | Canon MF8180C Color Laser MFC Printer
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Brother DCP 7010 Multifunction Laser Copier Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
