Acer travelmate 2413lci laptop wi-fi problems
The acer travelmate uses the ''Broadcom Corporation BCM4318 [Airforce one 54g] 802.11g wireless lan controller (rev 02)
i came across a little utill which i used in the terminal which gave me a list of stuff which this laptop has,
i have installed the Network Manager program but this does not see my wireless lan.
please, please any help would result in me sending you my wife for the weekend
i've searched Broadcom but only found riad drivers and acer only seems to have windoz drivers.
Ethernet controller driver needed for acer travelmate 2413lci
Hi Stuart1948,
Click below and download LAN drivers depending on the Operating system of you Notebook:
Feb 15, 2011 | Acer TravelMate 2413LCi Notebook
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
Wireless Card not working in Ubuntu 9
I had the same problem on my Acer Aspire 5920G, I have Intel wi-fi tho. Kernel update fixed it, but be careful when updating kernels. The network part of it can be updated separately. Check ubuntu forums about how to update kernel.
Nov 10, 2009 | Dell Inspiron 5100 Notebook
Problems with Acer TRAVELMATE 2300,Lan drivers have an driver that dont work ( filename: Lan_Broadcom(5708)_6.64.0.0_XPx86 ) BRG. Peter
Aug 07, 2009 | Acer TravelMate 2300 Notebook
Upgraded Acer 2500 Travelmate with a Wireless card
you can find the driver from here. download and install to use Wi fi
May 30, 2009 | Acer TravelMate 2500 Notebook
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Re: CAnnot find drivers for laptop
Hey Domp8
Check out the link below for the Wireless Drivers
and heres the LAN driver
Hope this helps,
Apr 01, 2008 | Computers & Internet
Problems with wifi lan configurantion.
hmmm... is the wireless card listed in the device manager at all? even as a yellow question mark?
do you have a USB wifi adapter you can test on this computer?
Mar 29, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Is 54g certified by the Wi-Fi Alliance?
54g products can be certified today by the Wi-Fi Alliance for interoperability with 802.11b products. Broadcom is working with the Wi-Fi alliance to accelerate interoperability testing among 802.11g products.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
378 people viewed this question
David Payne
David Payne
