Question about Sony PlayStation 2 (PS2) Console
My Playstation 2 Console Keeps 'Freezing'
My console (NOT the slim version) makes clicking noises when it tries to read the disc. It can occasionally play the disc in which case, it will load slowly and 'freeze' or 'lock up' often. But more often then not, it won't be able to play the disc at all and just have a black screen where nothing happens. What can I do?
  • 64 Answers
Well, you have one of two things going on. Either A.) your laser lens is dirty or B.) Your laser lens is out of alignment.
Using lens cleaner kits are useless for any cdrom or dvdrom if you're a smoker and smoke around your PS2. Reason I say this is nicotine and other resin forms cloud your lens over time and create a film on it.
By what it sounds like to me is since it's reading disks part of the time and kinda works, that your laser lens alignment might be ok. However, don't rule this out completely.
First, do a cleaning. Power on your PS2 and open dvdrom tray via the button on your console and power down the PS2 via the switch on the back. The point of this is to keep the dvdrom tray open as you take apart your PS2 so we can get at the lens. Take the PS2 apart (flip it upside down and remove the 8 screws from the bottom, 4 maybe covered up by rubber and plastic square plates so remove those to get at the screws) Next, take the top of the PS2 off and look at the DVD assembly, there should be four screws that keep the lid on the dvdrom. Remove these four screws and take the plastic plate off the top of the dvdrom. Watch this video and clean the following items:
Put your PS2 back together and test. If this doesn't work let me know and i'll go over instructions on how to align your laser lens. But i'm quite sure, by what you have told me, that this is your problem.
Posted on Nov 27, 2008
Spindle motor wont spin and lens are clicking ! ps2 slim problem!
seems like you need to go buy a lens cleaner from bestbuy or something. Run it repeatedly untill it works. sometimes it takes a while. But it will work after. please rate@
May 05, 2011 | Sony PlayStation 2 Slimline Console
When i turn on my ps2 slim it makes this clicking sound and then it says "the disc could not be read" please help its annoying
you may need a new laser. the clicking noise is it moving back and forth trying to read the disc, it'll go the end and skip a few times come back and repeat the process until its satisfied that it cant read the disc. replace the laser and you should fix the problem.
Jan 23, 2011 | Sony PlayStation 2 Slimline Console
Every time i turn it on it will make a grinding noise ant it wont stop
If the grinding noise occurs while you have a disc inside then it could be the len rubbing against the Cd. This problem normally happens in Slim Line editions of playstation2's. If the disc is blue coated, the playstation2's lens finds it hard to read the disc. Resulting in the lens moving closer to the disc. This is avoidable, try standing up your playstation. Or avoiding Blue coated disc.
Jul 28, 2009 | Sony PlayStation 2 (PS2) Console
PS2 slim will not read disc and making a scraping noise
Hi, the optical lens assembly is damaged. you will need to replace this assembly asap. the assembly has become unstable and the alignment is compromised.
Jun 05, 2009 | Sony PlayStation 2 Slimline Console
Psp slim dosent read umds dono whats wrong makes a little noise
Is this happening with every UMD? If so the laser has gone bad. Google tutorials on how to replace it or have it replaced.
May 31, 2009 | Sony PlayStation Portable (PSP) Console
it might be that your lens that reads the psp is dirty so it cant read them
May 28, 2009 | Sony PlayStation Portable (PSP) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Disc reading error
Open the Case.
Clean the lens with Q-tip and Alcohol. This is only if you have the SCPH-30000 through 5000X models. If you have the Slim Ps2 do not use Alcohol on the lens. Use Glass cleaner instead.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Not loading game
the reason it makes the "grinding" noise is because the motor that moves the lens to read the disk is dieing, this generally happens when you have played your ps2 for a long time, this only happens to older consoles.
Nov 01, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Makes Sounds and Keeps Pausing Games
Hi Ebridges2,
The Game your playing is probably a Blue colored media.  That is ones that spin so fast.  You console has become dusty and loaded with lint probably.  You can open the case and clean up the insides. Also while your in there, remove the ocver and polish up the lasers lens.  This will probably get you back in business. If you do nto have success, contact me at Repairtech@   I run The Playstation Clinic at  If you have a Slim Model it will cost more than the big model to repair.  The slim model is $41 full refurbish including return shipping inside the USA.  The big Fat PS2 Versions are $36 including return shipping.
Oct 14, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
1,173 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
