Question about ASUS P4B533-VM Motherboard
PC will not recognise new DVD Burner
Optima PC with ASUS moterboard P4B533-VM.
Have fitted new LG DVD burner Model GH22NS30 using Ritmo controller model CC-PS853 plugged into PCI slot. PC recognises controller and has loaded driver but altho' burner is powered OK cannot get Hardware Wizard to recognise burner.
  • thecoolone77 Mar 24, 2009
    Hi! I just got the LG DVD-RW GH22 with SATA cable.I plugged it into my computer and in the bios it is the but when i start my windows xp it's not there?Need help.....Please.Thanks
  • 849 Answers
If the recognized it then the wizard will not appeared. u need to install application software for burner like nero, alcohol etc
Posted on Nov 27, 2008
My lg (gh22ns30) dvd+rw burner will not read a dvd or dvd rom.
You can go to the control panel, then to device manager, click on disk drives. Make sure you have the right one and then delete it. Restart the computer and it should "find" it and install it, that is if it still works.
Feb 24, 2012 | LG (GH22NS30) DVD+RW Burner
Can i change the lens of dvd
No you cant you will be better off buying a new drive
Feb 15, 2012 | LG (GH22NS30) DVD+RW Burner
An audio multi media driver for asus p4b533
1. Usually going to the manufacturer site is a good place to download any lost or corrupted drivers or installation software.
You may also call the manufacturers customer service line and talk to a customer service agent or tech will be happy to assist you in getting the driver or installation disk you need to restore your PC unit to factory default and beyond.
You will need to know the model number and operating system information to give them a mental look at what they are working with.
I hope this helps. Have good day!
Jun 18, 2010 | ASUS P4B533-VM Motherboard
RIBBON CONNECTOR WILL NOT FIT LG BURNER
IF the connector doesn't fit it MAY be the data buss is NOT compatible.
You should verify that the data is the same such as IDE which is different thab SCSI which is also used.
You dod not put model numbers so that any of us could investigate for you. Find the model numbers and then use Google to find what data format the unitss are such as IDE, SATA, or SCSI and make sure they are the same.
Jan 15, 2010 | LG Computers & Internet
I have a PC with an ASUS P4B533-VM MoBo. I got
Hello.
According to Crucial, your MB takes either DDR PC2700, or DDR PC3200, NON-buffered, NON ECC modules. Another consideration is density. Some cheap high density modules will not work in all MB's.
Refer to:
http://www.crucial.com/store/listparts.aspx?model=P4B533-VM
Have you tried to see if it will POST with just one module installed? Try both individual modules and see if there is any success. It may be that one is bad.
Thanks for using Fixya.
Wayne
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Vista can't detect de DVD rive LG gh22ns30
If u are using vista then do not install any extra driver for any removable drive. In vista one cannot install any drivers other those already in its database. I hope your DVD drive is Vista compatible, otherwise it will behave the way you mentioned it..................sodeep
Jun 28, 2009 | ASUS P4B533-VM Motherboard
PC shuts down on Asus P5sd2-vm with LG DVD Rw (GH22NS30)
If you are sure that it works with other DVD drives, then I cannot help.
But if a system shuts down suddenly, the first thing I would check would be the CPU temp. At around 97 degrees, Intel processors shutdown to protect from excessive heat. Go into the setup (some call it BIOS) and check cpu temp.
If that's not the problem, then you should consider things like drivers problems, virus infection, broken hardware, compatibility issues. Try to search technet site at microsoft for a similar problem.
Good Luck!
Tareef Attar, MCSE, CISSP, CISA
Dec 19, 2008 | Computers & Internet
ASUS P4B533-VM Motherboard Logo
303 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
