Question about Epson LQ 2070 Matrix Printer
I have a problem getting a pdf output from a asp application
It was first working fine but when the printer settings were shcnged then after words the print out that the pdf which used to show full text now it is coming on the next line of the pdf that means if  i m going to print a page from the application the print out shows me half page in the forst page and the other half on the next page even in pdf forma  i wonder what would have gone wrong !!!!!!!!!!!!!!!!
5 Suggested Answers
SOURCE: Epson rx420 printer
Another post suggests that you printer is dead -see ( but I've had the same problem - things seem to be ok after I reset to the defaults in the main page of the printing preferences.
Posted on Mar 15, 2008
  • 63 Answers
SOURCE: the printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Posted on Feb 10, 2010
Testimonial: "Thank you so much, I no longer have a problem. It seems such a simple solution now I know the answer! I thought it was something major."
  • 797 Answers
SOURCE: all-in-one printing half text. breaking words.
Try running the cartridge cleaning. Most likely one some of the ink jets are clogged. You can also try removing the cartridge and cleaning the ink jets with some alcohol
Posted on Mar 14, 2010
  • 162 Answers
SOURCE: my printer does not print full page.
I think the problem is with the data transmission from your pc to the printer. Try switching usb port for your printer. Unplug your printer usb cable connected to the pc and then plug it to other usb port.
If this doesn't work, replace your usb cable. Buy a version 2.0 compatible.
Hope this helps. Please rate me :)
Posted on Jun 04, 2010
I cannot print PDF files on my Lexmark X4650. Word docs print fine, but Adobe files will not print and I cannot convert them to word either.
Make sure your Adobe application is updated.
Try to update your printer driver as well. Please visit the Lexmark website to download and install the Lexmark X4650 Printer Driver on your computer. Select your operating system > download and execute the file.
Once the update is complete, try to print a PDF file again to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X4650 InkJet Printer
Hello. we have a Dell 3115 multi function machine. it automatically saves scanned documents as a pdf...can the setting be changed to save as a word document?
Scanners can only create JPG and PDF files by default. If you get a program such as FineReader, then you can convert those files into Word documents. That's your best bet.
May 16, 2011 | Dell 3115CN
What software do I need to convert word, jpg and other files to PDF format?
The easiest way I've found is to use CutePDF. It installs itself as a virtual printer, only when you "print" to it, you get a PDF document output. Download it for free here
Feb 04, 2011 | HP Computers & Internet
I have hp color printer with scanner. I need to scan document and generate pdf document. Dont find ocr software any help?
If you do not have the install CD that came with third-party software (or you have a OS that is not compatible with that software), you will need to get a OCR program. SimpleOCR ( ) is free but doesn't handle pages with columns well. (It merges across the column breaks instead separating the paragraphs.) It also doesn't handle handwritten text. This software outputs to a file for a Word Processor (such as Microsoft Office's Word). Most word processors either come with a PDF converter or have one available as an add-on. The commercial OCR software packages will include the save as a PDF function and do not have the limitations of SimpleOCR; although they also default initially to a format for Word Processing (to correct any mistakes). (I have used OmniPage at times personally.)
With most all-in-ones, if you have the full software installed, there will be an option for saving as a PDF. (This is true even on the versions that weren't bundled with OCR software.) If you have a generic OS driver or the basic driver, this will usually not be available Take a look at the screens that come up if you start the scan from the computer. (There will be a place to adjust settings, including the resolution and the output type.) This won't be editable unless you go through the OCR software.
I hope this helps.
Jul 23, 2010 | Dell 922 All-In-One InkJet Printer
Problem with size of scanned document using HP laserjet 3380
It depends also on what you are scanning....half tones, pictures etc. but the easiest way to control the file size of PDF's is to change the resolution setting. Also referred to as the quality setting. These are settings like Super Fine, Fine, Standard. It should be right on your control panel. It is the same setting you can change when sending a fax. If your default setting is Fine for example, changing it to standard will use a lower resolution and reduce the file size. In other words the higher resolution/quality setting you use make the file size much larger.
Good Luck and Thank You for using Fixya.
Apr 06, 2010 | HP LaserJet 3380 All-In-One Printer
No pdf output
does the printer work with word docs? Go to adobe reader, open a pdf, then check that printer is selected, and do a test print job
Nov 27, 2009 | HP Deskjet F4210 All-In-One InkJet Printer
Donwload multiple files from server to client using
//To Get the physical Path of the file(me2.doc)
string filepath = Server.MapPath("me2.doc");
// Create New instance of FileInfo class to get the properties of the file being downloaded
FileInfo myfile = new FileInfo(filepath);
// Checking if file exists
if (myfile.Exists)
// Clear the content of the response
// Add the file name and attachment, which will force the open/cancel/save dialog box to show, to the header
Response.AddHeader("Content-Disposition", "attachment; filename=" + myfile.Name);
// Add the file size into the response header
Response.AddHeader("Content-Length", myfile.Length.ToString());
// Set the ContentType
Response.ContentType = ReturnExtension(myfile.Extension.ToLower());
// Write the file into the response (TransmitFile is for ASP.NET 2.0. In ASP.NET 1.1 you have to use WriteFile instead)
// End the response
private string ReturnExtension(string fileExtension)
switch (fileExtension)
case ".htm":
case ".html":
case ".log":
return "text/HTML";
case ".txt":
return "text/plain";
case ".doc":
return "application/ms-word";
case ".tiff":
case ".tif":
return "image/tiff";
case ".asf":
return "video/x-ms-asf";
case ".avi":
return "video/avi";
case ".zip":
return "application/zip";
case ".xls":
case ".csv":
return "application/";
case ".gif":
return "image/gif";
case ".jpg":
case "jpeg":
return "image/jpeg";
case ".bmp":
return "image/bmp";
case ".wav":
return "audio/wav";
case ".mp3":
return "audio/mpeg3";
case ".mpg":
case "mpeg":
return "video/mpeg";
case ".rtf":
return "application/rtf";
case ".asp":
return "text/asp";
case ".pdf":
return "application/pdf";
case ".fdf":
return "application/vnd.fdf";
case ".ppt":
return "application/mspowerpoint";
case ".dwg":
return "image/vnd.dwg";
case ".msg":
return "application/msoutlook";
case ".xml":
case ".sdxl":
return "application/xml";
case ".xdp":
return "application/vnd.adobe.xdp+xml";
return "application/octet-stream";
Good Luck
Aug 17, 2009 | Microsoft Designing ASP.NET Applications...
My parents have a HP P1505 and they are having trouble printing from InDesign documents. They get intermittent and funny type issues when printing straight from the document. Prints fine from a PDF. Prints...
Go to indesign. Under print options, go to output and select Greyscale instead of RGB. This takes acre of outputs from Indesign. I think the problem arises from the printer trying to interpret the colors.....
May 07, 2009 | Office Equipment & Supplies
Printing problem, preview problem
download and install pdfcreator in your system... it acts like a printer and so you set you printing destination to pdf creator and it will give the output that the printer would have given in the form of a pdf.... so you'll have what would have been the printer output... after checking this you can set printing destination to printer and get your doc printed.... or you can print the pdf...
May 14, 2008 | ComponentOne VSVIEW Classic Edition...
Epson LQ 2070 Matrix Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
