Recently, blew a 2.5a fuse on the power supply board that appears to control the output voltages from the power transformer. I replaced the fuse which has not blown since replacement. Now, no sound. No delay speaker relay that normally clicks on about 2 seconds after power up. Checked continuity of the 3 fuses I could find, all good. Any ideas? Have DVM and basic tech knowledge so I can follow instructions/suggestions.Thanks!
SOURCE: Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
