Question about Samsung Televison & Video
Check fan 2 error
Samsung dlp 67"
check fan error comes on screen.. and then shuts t.v. down.. we have had in shop many times.. and they can't figure it out.. it doesn't do it when it's there.. however they are loading it in the back of a truck.. and then driving down the road.. so i think it may be blowing the fans out..
help?
  • 905 Answers
If moving it changes the problem , then either there is a bad solder connection or the fan has a bad connection also poor connections in the wall socket can also cause strange happenings in the set
Posted on Nov 27, 2008
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 10, 2014 | Samsung DLP HL-P5663W 56" TV
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
Jun 05, 2012 | Samsung 61" Slim-Depth LED DLP HDTV
I have a 67" samsung
Check the lamp if its more than two years old, otherwise check the color wheel.
Jul 24, 2011 | Samsung HL-67A510 67" DLP HDTV
I have a 67" DLP TV and last night 2 white spots
That usually indicates that the optical block is going bad. That repair is usually 900-1100 dollar fix.
Mar 30, 2011 | Samsung HL-67A510 67" DLP HDTV
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
HI I have a 2 1/2 yrs old Samsung 48'' DLP. just recently it has developed a whirring noise it appears to come from the rear of the TV and to me a(a layman) it sounds like a fan, every time I shut it down...
sounds like bushing worn out in fan motor solution replace fan fan important it increase the life of lamp sugg mouser electronics.com shoulid have part 4 around 60.00 bucks
Jul 25, 2009 | Samsung Televison & Video
SAMSUNG DLP MODEL HL-S4666W
Bad capacitors on the power board. Yes you can do the repair yourself.
Sep 07, 2017 | Televison & Video
Samsung 50" DLP TV
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Dan
Jun 27, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung 56" shuts off after 5 or 10 seconds see a checker board image before shutoff
When the set shuts down you need to see what lights are blinking. For example: Timer/ Temp/ lamp on the front panel. You should also count the number of times they blink and the sequence. Most DLP`s give an error code alerting the technician to check the balast, lamp, or fan etc. for malfunctions. Unfortunately I can not tell you exactly what is wrong given the current information. Howrver, the last Samsung I repaired for shutting down had a bad light engine.
Nov 29, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
195 people viewed this question
Jerry Greenberg
Jerry Greenberg
