Question about Pyle PLA1485R Car Audio Amplifier
Treble come out with lowpass filter on
My Pyle PLA1485R works great except the fact that when it is on the lowpass filter it still puts words through the sub. i have turned the hurts down completly and i have also turned the hurts down for the highs but it does not make a difference. it also makes a kicker cvr respond really weirdly. it will push the sub out of the housing and procede to make it bump then sucks it back in the basket hits some more than goes back out.this sub works fine on other amps and the amp does not do that to any other subs. is my amped fucked or is it worth getting it fixed?
Re: treble come out with lowpass filter on
Get it fix but sounds like a low current problem check cable connections
Posted on Aug 09, 2007
0 characters
3 Points
How many ohms can a db drive a290 handle
# of Channels 2 (Stereo) RMS Power (Watts Per Channel) 90 x 2 @ 4 Car Amplifier Features Highpass Filter, Crossover, Lowpass Filter, Bridgeable
Feb 22, 2014 | DB Drive A290 Car Audio Amplifier
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
Apr 01, 2010 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
Amp wont turn on
have you checked the remote wire is supply power? try jumping the main power wire t the remote wire to see if it turn on. Also check that your ground wire is securely making contact.
Apr 20, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Alpine mono power mrd m500 amp
Try switching the lowpass filter down to 80hz or lower, then adjust the bass boost to your liking.
Jun 28, 2008 | Car Amplifiers
Autotek 7100 BTS series
99% of pots are off the shelf items.
See a tech with a parts catalog and a soldering iron.
Labor will far out price, the part.
Experience ain't cheap.
Regards, Sumthin
Jun 10, 2008 | Autotek MX3000.1 Car Audio Amplifier
The Amp stays on because you have a constant 12V to the Remote.
If your stereo remote is no longer working then run a wire from a 12 volt source that turns on and off with your ignition something like your radio fuse in the vehicle fuse box.
As far as the Bass Knob if it is connected properly and still not working check the line for wire kinks or cuts that may have happened during installation if you cant find any problems you can get a universal bass knob that plugs via your RCA cables for under 20 bucks.
Hope this gives u some ideas.
May 05, 2007 | Pyle PLA2480 Car Audio Amplifier
Pyle PLA1485R Car Audio Amplifier Logo
75 people viewed this question
Top Pyle Car Amplifiers Experts
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Pyle Car Amplifier Expert? Answer questions, earn points and help others
