My AC compressor fan stopped spinning and upon opening the unit, I found the capacitor had blown. I replaced it, but now the fan only spins at low speeds and the compressor doesn't turn on at all. The contactor is getting 26 volts and moves freely, but it only seems to be sending out 120 volts. The compressor and fan motor are 208/230 volts. Is it possible the contactor is bad and the voltage is not high enough to run the fan at a normal speed and turn on the compressor? Or is it likely the fan motor that is bad? Also, the fan motor will spin even if the thermostat is set to off. The only way to get it to stop is to remove the disconnect.
The contactor is a power passing device.Even though it is closing, it is possible its not passing the required voltage to operate other power consuming components such as the compressor and fan.Being exposed to the elements it's common for the contactor to go bad.They are fairly inexpensive and I would start by replacing it first before accusing any other component.
Yes!, At this point I would recommend an electrician only because you stated you have never attempted wiring and I assume any electrical inspection,troubleshooting or repairs. You are dealing with high voltage which as you know is very dangerous.Good Luck!
Let me add that it might be as simple as a loose or corroded electrical connection to the disconnect, but once again I recommend a qualified electrician investigate.
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
SOURCE: home ac compressor fan won't turn all the time.
your looking at $175-$225 for just the single phase motor depending where you purchase, I just replaced mine(identical unit) due to screaming dry bearings, if you replace it your self make sure to keep new wires tight along side of unit or fan will cut them if loose and its a fan- 5mfd/25mfd compressor@440volt cap
Testimonial: "Thank you, you gave me exactly what I asked for. Now I can shop wisely. Tim"
Bryant 561CJ024-E
Thanks for the suggestion!
I have some new information to add. If I measure the voltage across the circuit breakers for the AC, I get 120V individually and 240V across both. When I measure at the disconnect, I get 120V on one side and less than 50V one the other. So, now it sounds more like a wiring issue. This problem might be a bit out of my league as I've never attempted wiring before. Should I call an electrician?
