Question about IBM ThinkPad T22 2647 Notebook
Keeps restarting i turn on my laptop and it a balck screen comes up asking if i want to start windows normally, in safe mode, or the last settings that worked but no matterwhich one i choose it just restarts
  • Dominic
    Dominic May 11, 2010
    Sounds like the hard drive is corrupted from a improper shutdown or you have a driver issue that is preventing your system from booting properly. Did you recently install new hardware? Moreover, your Operating System may need to be reloaded, do you have irreplaceable data on the computer? Furthermore, did your system come with a recovery disk?
    Genius:
  • IBM Master
  • 1,250 Answers
Your OS has got corrupt, reinstall it
Posted on Nov 27, 2008
I have dell vostro 1014 with windows 7. i tried to install ZoneAlaram antivirus version 9. and i t got sucessfully installed and asked whether to restart or not. i opted for restart. while restarting its...
It sounds like windows doesn't like a driver that zone alarm installed... when the PC starts, just tap on F8 a few times until the screen pops up to offer you to go into safe mode... select "Last known configuration" (i.e. the configuration that worked prior to installing zone alarm...
it should reboot and all should be well...
Check the version of Zone Alarm to ensure it is compatible with Windows 7...
Mar 10, 2011 | Dell Vostro 1014 Laptop Computer
My laptop wont come on a screen keeps coming up asking to repair or start windows normally i have tried both without success
When was the last time you were able to use your computer?
Did you installed any software recently in your computer?
Try pressing F8 on startup and use the Last Known Good Configuration. May be that will help.
Feb 28, 2011 | Toshiba Satellite Laptop L655S5150
My laptop was a gift xmas 1 year ago. when i turn it on there is a black screen and then there is this message ; it say sorry for this problen windows didn't start normally. then it gives me 4 or 5 choices...
#2 "safe mode with networking" will only work if you were attached to a local network and configured to boot from it. This is not the normal configuration for most users. The network they are referring to is NOT the internet.
You should try #1 and after it is booted try a restart [Start], [Shut down], then use the pull-down to select Restart. If once it
Feb 25, 2011 | Computers & Internet
My computer is having start up issues. When I turn it on it'll act like it's loading normally and then it'll beep twice. It'll go to a screen that will have several ERRORs on it and ask me to press either...
It may happen when CMOS Checksom error i.e error may happen due to keyboard failure. Please follow the steps to short the BIOS
> Open the Laptop back panel. Locate the CMOS battery, remove it & then with the
help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a
screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Now, restart the computer in normal mode. If still facing issues then I would suggest a full system recovery.
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 28, 2010 | Acer Aspire 5100 Notebook
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
When i turn it my eee pc on it pops up to where it says windows and thats as far as it will but it will only load up in safe mode
Try restarting your notebook and hit the "f8" key after you see the first screen come up. Keep hitting the F8 key until you see a menu that says "start in safe mode" start in safe mode with networking......
Start in last known good configuration....Start windows normally.
Try using Start in last known good configuration.
Hopefully, that will solve the problem that is hanging up your windows from starting.
Brian
Mar 01, 2010 | ASUS Eee PC 1000H Laptop
The command prompt does not come up. Ive got a Avertec 6100 that doesnt boot. It give me a screen that asks me to: SAFE MODE SAFE MODE W/ NETWORKING SAFE MODE W/ COMMAND PROMPT LAST KNOWN GOOD CONFIG START...
You are experiencing either a memory issue or OS problem.
First, remove all your memory modules and insert one at a time to test.
If still a problem, try Windows Repair.
If necessary, reinstall Windows.
Hope this helps.
Aug 13, 2009 | Averatec 6100 Notebook
When i turn on my laptop, it will say there was a problem starting windows and then asks me to choose either safe mode, safe mode with networking, last know configuration, or start windows xp normally. ...
Good day.
Usually that problem occur when their was changes made in your laptop maybe settings, or defualt setting before the computer was restarted, that makes the windows react that way or maybe virus infect your laptop. Some problem can be solve in safe mode, but since safe mode cannot be fixed, I think you have to re-install the program, but you have to back-up first all your important files before you fixed it.
Thank you.
Oct 28, 2008 | Computers & Internet
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
Laptop won't comeback on
Try safe mode.
On safe mode return the computer to an earlier date configuration.
At some point will ask if you want to do that. And say yes.
Make sure that if for some some reasons it asks you to restore the computer to factory settings, you should say no. I hope you can do this.
Mar 31, 2008 | Toshiba Satellite 1405-S151 Notebook
IBM ThinkPad T22 2647 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
