Question about MotorGuide Electrical Supplies
MotorGuide pro series 46 lb.thrust not turning smooth
My trolling motor is 3 years old and recently began squeaking where the rotating arrow is housed.Now the foot control is not turning smoothly.I tried spraying wd-40 around the rotating arrow but no luck.Please help.
John Whitcomb
Mobile,Al.
Check the beaing locted where the inner shaft passes thru the outer tubing below top of motor
Posted on Sep 08, 2009
  • 5,568 Answers
Can't offer a solution but did want to mention that WD-40 is a penetrating lubricant, not a lubricant.  Try it yourself; just spray a film on anything that is around room temperature, you'll find that it evaporates fairly soon- within a day or two. It's great for loosening stubborn nuts and bolts but not for the long run.
Posted on Dec 15, 2008
I nned a motorguide 46 lb. thrust electric foot controlled trolling motor manual
Go to http://www.boats.net. Let me ask you a question, is it 5 speed? And if so have you lost some or all speeds but 5?. I so, them you need to take the lower unit apart and you will find solder laying in the bottom. You will see that the speed control coil wires at one if the terminals on the brush board has no solder. Clean it up along with the wires so that you see copper and re-solder. This is due to poor quality control on soldering at the manufacturer. When you re-assemble tighten the bolt 45-50 in-lbs only. No more.
Oct 02, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Feb 15, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide brute 567, 67 lb. thrust
you will probably find it is either a switch problem or your wiring this is a twist handle?
Sep 29, 2008 | MotorGuide STANDARD MOTOR REPLACEMENT...
Electrical Supplies Logo
1,179 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
