Question about Casio Exilim EX-S600 Digital Camera
Casio ex-s600 brand new camera wont turn on,worked fine for 3weeks,then not used for 3mnths.Shows images while in dock,but Red charging light flashes,indicating not charging.Casio Tech-Help suggests new battery?
  • gery nordstrom Jan 13, 2007
    thanks yes that was it. went to a (different) radio-shack, asked about a new battery,was told it must be ordered,after i whined about spending $350 for the camera, the manager went to the back-room and (miraculously)came back with a new battery. poppd it in and said "have a nice day". i love how they can do that....
    Sergeant:
    Champion:
  • 326 Answers
Hello Gery, Try with the new battery. Best regards, Arpad
Posted on Jan 11, 2007
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Jun 10, 2010 | Kodak EasyShare Z760 Digital Camera
Camera wont charge
Hi, if you are using the KLIC-5000 battery try to clean the metal contacts on the battery. Try also to remove the battery of your camera dock your camera on the docking station then turn on the camera, if the camera will not turn on it means the charging mechanism of the dock is defective. Now if the camera turns on it means the battery is defective that is why you can charged it.
Feb 11, 2010 | Kodak EasyShare Z760 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Mar 14, 2009 | Kodak EasyShare Z760 Digital Camera
Charging...Red Light
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Oct 05, 2008 | Kodak EasyShare Z760 Digital Camera
Red flashing light, constantly.
this is the fix.
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Jun 02, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Kodak CX7430 can only take 10 pictures with a new battery
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Mar 08, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Casio digital camera ex-s600 won't turn on
*** SOLUTION *** Mine had the same problem. My camera works now. What did the trick for me was removing the Flash Card. It appears card went bad and the camera would never power on because of this. I just removed the card and the camera powered on. I tested the card on my printer and it wont let me read or reformat. Hope this helps. -HenryVerde
Aug 08, 2007 | Casio Exilim EX-S600 Digital Camera
New Camera Does Not Charge
A red flashing light does NOT mean it charging. THat means you have a defective battery. Call tech support and tell them that you have a defective battery and they may be able to get a replacement for you.
Jun 08, 2007 | Casio Exilim EX-S600 Digital Camera
Please help
It should still be under warranty, sounds like the rechargeable battery has died, either take it back to the shop or buy a new battery.
May 03, 2007 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
139 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
