Question about Faberware Eltron P210C Color Card Printer (P/N P210C-0000R-IDO)
Card feeder When we insert a card for printing it only feeds partially and then stops before it gets to the print head. The card is then stuck in the feed roller and has to be forcefully removed. Any idea what could be causing this and how to fix it? Thanks, Glenn
It's not a card it's just paper
Posted on Nov 03, 2007
Won't print and the hand with the cloth light is lit. Put in a cleaning card and held down the feed but the card is still in the hopper.
Open printer properties . Click on Tools tab.
Click on printer Self Cleaning button.
Remove any ribbon from printer and cards from feeder.
Adjust thickness lever just near feeder to full 1mm.
Insert cleaning card in feeder and click on start cleaning button.
This should definitely solve your problem.
Feb 17, 2011 | Evolis PEBBLE 4 Led Card Printer
What is the best way to clean the printing "head"?
Use a Thermal Printer cleaning card. I get mine in with my labels. First turn power off on the Thermal Printer. Insert the card into the feeding path, press form feed or manually pull the cleaning card using both hands until the entire card has been pulled free.
Nov 18, 2010 | Zebra Eltron LP 2824 Thermal Printer
I have an Evolis Pebble 4 printer. I am trying to print out cards from the Pebble 4, but the machine is not pulling the cards from the card holding tray. Because the cards are not being pulled from the...
Just check for thickness adjustment pointer near card feeder . It should be 0.8 for standard cards.
Check in driver settings also if you have selected for manual feeding.
You may need to clean the Roller situated at feeder.
Oct 14, 2010 | Evolis Pebble Color Card Printer
After a stuck document in the printer (HP Photosmat all in one C309 series, it doesn't seem to recongize we have cleared the jam and it will now ONLY print if we use the sheet feeder.
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 31, 2010 | Computers & Internet
My Evolis Pebble 3 says feeder error but there is not. It won't pick up a card when you try to print but when you press the push button it feeds out a card without printing. It will alos not print a test...
You must take following approach
1. There is a lever at feeder for thickness adjustment . Check it for proper thickness.
2. There is a hanging lever which acts as a card presence detector just where you place cards check if it is stuck and try to clean sensors aside it by blowing air .
3.Check if feeder motor is working by giving Mf;+ command
4.Check for proper ribbon setting.
5. Try downloading firmware which is available as an exe file for different models on Evolis site.
6. diagnostic software is also available on site.
7. You can also do self adjustment to adjust sensors.
Aug 16, 2009 | Evolis Pebble 3 ID Card Printer Package...
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
Clean prinnter massage
The Zebra printer displays the Clean Printer message when the printer prints a 1000 cards.
This is to maintain printer and ensure good print quality.
The way to clear the message is to get cleaning cards and run a cleaning routine.
The CD that comes with the printer will run a video showing how to run the cleaning cards through the printer. Printer needs 2 unique cleaning cards (1 short & 1 Long)
Feb 01, 2009 | Zebra P330i Thermal Card Printer
Printe paper jam problem for brother dcp135c
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 08, 2009 | Brother DCP 130C All-In-One InkJet Printer
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
91 people viewed this question
Top Faberware Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Faberware Office Equipment and Supply Expert? Answer questions, earn points and help others
