Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
My External USB 250hard drive shows error Drive is not accessible
Well I am using a 250GB external Hard Drive hooked up via USB from my Laptop XP machine and is working excellenty but yesterday while working the drive just stopped reading.
I unplugged it and I hook it back up to my machine.
G:\ is not accessible. the file or directory is corrupted and unreadable.
I ran a check disk and it fixed an error under xp. The drive letter shows up but the drive size shows 0kb.
How can I solve the problem
  • 32,281 Answers
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Posted on Nov 27, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
REQUIRE WINDOWS 7 DRIVER FOR IOMEGA SILVER SERIES 250GB EXTERNAL HARD DISC DRIVE. THANK YOU
The external hard-drive is "plug-and-play", and Windows XP/Vista/7 all support "plug-and-play".
Thus, it should automatically be detected by Windows.
So, what's your "real" problem? Symptoms? Error-messages? What happens? What does not happen?
Nov 05, 2010 | Iomega Silver Series External 250GB...
Wd 250gb laptop HD only shows 118gb
In XP Start > Control Panel > Administrative tools > Computer manager then on the left click disk managment, you will see your 250gb drive as drive0 most likly with partition C and beside it you should see unallocated space, you can right click this unallocated space and format it, then right click again and click make partition active.
Jun 20, 2010 | Western Digital 250GB MyBook External USB...
SimpleTech 250GB External Hard Drive can't be recognized
First of all,
uncheck the "Allow the computer to turn off this device to save power" option in the device manager for USB Hub Properties, Power Management Tab.
Try rebooting the computer once as C:\Windows\inf\INFCACHE.1 file may be corrupted and need to be replaced (either restore a previous version or just delete it and try connecting again).
Next,completely uninstall all USB devices and the main hub and then re-install.
Sep 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
Jan 12, 2009 | Western Digital WD2500JS 250GB SATA2...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
219 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
