Question about Whirlpool RBS305PD Electric Single Oven
Broiler won't turn off. Error code F-3
Our oven's broiler turned on and won't turn off. Noticed an error code F-3. Can't do anything else.
We've turned off the circuit to the oven to be safe. When we open the circuit again, the broiler immediately comes back on. broiler won't turn off. My stove is a Whirlpool. I have to turn the breaker off to it. I did see an error code F-3 too.
    Scholar:
  • 31 Answers
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Posted on Jan 08, 2009
  • 3 Answers
SAME PROBLEM. Came home yesterday and house was literally 90 degrees or MORE from this staying on. The oven door was open though, so I'm sure helped heat the house up. Thanks for the solution. Have to shut breaker off to shut broiler off. Glasstop Kenmore stove.
Posted on Mar 04, 2010
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Posted on Dec 13, 2011
Hi.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
F7 error built-in oven
F7 is a stuck keypad error. Sometimes you can push every pad at random several times each to unstick the keypad.
If that fails the ERC(clock) will have to be replaced.
Dec 04, 2009 | GE 30" Built-In Single Electric Wall Oven...
Kenmore oven does not seem to be turning off.
if the broil element was on and the door closed then the oven may have encountered an over temperature issue. i would need your model number and the error code
Nov 26, 2008 | Ovens
hi there,
can you provide the model # off your stove please?
Sep 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool RBS305PD Electric Single Oven Logo
4,631 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
