Question about RCA P60921 60" Rear Projection Television
RCA 60" Rear Projection TV Model P60925bl TV screen curved on the top and bottom. Colors are not aligned and images are blurred.
  • 905 Answers
This would be the convergence IC 's that need replacing
if you are going to have a tech come out to do the repair it will cost between 3 or 4 hundered dollars
if you are going to do the repair yourself ( meaning that you can solder and indentify the convergence chips and test the resitors on it) then it will cost about $40 or so
electech
Posted on Nov 27, 2008
Blurred pictures,displays green,red colors on screen,picture curve at top and bottom of screen
Go to Menu then setup Look For Convergence,If you Do Not see Convergence in the Menu then you have a Blowed Fuse on The deflection Board FL231.
Deflection Board is the Bottom Left hand side board that has (FBT) flyback Transfomer on it.
If you are Not able to repair it yourself ,then you can ship Board to PTS for repair.
1-800-844-7871
Jul 06, 2011 | RCA HD52W56 52" Rear Projection HDTV
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Curved double image at bottom of TV and looks like a 3d image
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Panasonic PT-53WX53 53" Rear Projection...
60 INC RCA PROJECTION CURVED PIC. TOP BOTTOM
This problem is caused by a faulty Convergence amp. This amp keeps all three colors aligned together and square on the screen. It could also be the power supply section that supplies power to this amp.
A local TV shop should be able to repair this for you for about $350
Jan 06, 2010 | RCA Televison & Video
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
PHILIPS 60PW936317 - COLORS GOT DISTORTED AS I WAS WATCHING TV
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking.  Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com. They are working on a complete kit for this model.
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
RCA P60921 60" Rear Projection Television Logo
296 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
