Hi i have 52" sony tv it's screen gets red and it turns off all by it self
  • 5,138 Answers
Red Tube Shorted, diconnected crt board on neck of red tube if set comes on playing tube is shorted. only 2 things will cause this red video ic on red crt board or tube.
Posted on Nov 27, 2008
Sony kdl52xbr9 it comes on i can see picture and sound for a couple of seconds, then it shuts off and blinks 6 times
Hi! and Welcome to Fixya!
Blinking red lights on the tv are error codes that explains hardware issues on the tv.
However, if after turning ON the tv and you will see the Sony logo on the screen before the picture goes off and then flashes red lights for a number of times, this could mean that tv can still be recovered. Try the option below to isolate possible issue with settings that cause your tv to shut off. Disconnect first all external devices from the tv
1. Turn ON tv first and wait until it flashes the red lights > press and hold down the UP Arrow button ( use remote control ) > while holding down the UP Arrow button, press the POWER button on the tv > tv turns off, wait until it turns on by itself > release the UP Arrow button when tv turns on
Note: reset is successful when you see a welcome screen on the tv and ask you to select your Language. This is the Initial Setup, just follow the on-screen instruction
If that solution did not resolve the issue then a service may be recquired.
Let me know if this helps!
Oct 27, 2015 | Sony Bravia Kdl52xbr9 52 1080p Lcd Tv...
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Turns on blue screen then shuts off
Hi Karen,
Your tv is going in protection mode due to some problem in side. Please consult someone qualified to fix it. I am sorry there is nothing you can do about it your self.
Jan 18, 2014 | Sony Kdl-52vl150 52" HDTV LCD TV
My tv model is sony KDL-52VL150 . problem is when i try to turn on after few second it gose standby itsalf's, and also i did unplug from power outlet & put it back & wait, but same thing,...
Hi Mizanur,
First of all, thank you for posting your question here at Fixya.
Your TV has a built in self diagnostic software that can help us diagnose accurately where the fault came from once the unit gone to malfunction. To activate it, press the following buttons on the remote control within a second on each other in standby mode( red LED is on), "Display", "5", "Volume (+)", "Power". Initial screen will be displays as follows :
To display the self diagnostic list, press12_14_2011_11_34_30_pm.jpg on the remote control.
The screen will display the list of error log as follows :
Numerical value "0" means that there's no error detected, "1" means that an error was detected.
Please let me know what error code(s) with numerical value "1" to continue our diagnosis.
Kind Regards,
Jdvillanueva
Dec 14, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
HDRCA 52" model R52WH77, the pic looks like a big U in the middle of the screen and it turns its self on after turning it off. Sound is fine.
A capacitor is building up power and then when there is too much power it discharges turning the tv back on without you hitting the power button. The tv will need to be repaired by a service tech however get a quote and then decide whether it is better to just buy a new tv. LCD's have dropped in price greatly.
May 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Power on - Screen Black non responsive
Hi...
Look into getting the main power supply replaced
Check the web for someone near you
Apr 22, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I heard a loud pop then tv screen went black, now
hi friend,,,,,,,
i think due to high voltage resistor in dma board has blasted,,,,,
did u see any burnt marks,,,,,,,,,reply me
thank u,,,,,,,,
May 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony 52 inch projection Screen keeps shutting off.
not if it keeps repeating the same cycle over and over..it cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Feb 04, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Rca 52" problem
If you are saying the picture comes on red and then the tv turns off?
I would suspect the video ic on the red picture tube pc board has shorted out.
This is a pretty common problem
Apr 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
268 people viewed this question
Top Televison & Video Experts
