SOURCE: unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
SOURCE: audio set up to xbox 360
There would be a RED,YELLOW,WHITE input cables that you would hook up to the back, there should be a Video mode on you remote turn it to one of the input channels and you should be fine.. Thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Can't connect my ps2 with my rca truflat
well if u have a VCR or DVD play with u can run it though the the vcr first then back up to the TV makes sure u have the correct channel on and if that is not the case u may have to buy a small switch box (wal-marrt) Cheap to add more AV in puts.
Let me know if this works!!
Thank U jayson
Please feel free to rate my suggestions.
we depend on your votes!!!
SOURCE: Hi My RCA TRuFlate tv turn on for one sec and its
G'Day!
Unfortunately, what you're describing is a repairissue. You won't be able to address the problem with troubleshooting.There is a part inside the TV that needs to be replaced. If you'reunder warranty, this will cost you nothing. If you're not underwarranty the cost will likely be a minimum of $200 parts and labor.However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
SOURCE: My RCA truflat tv won't turn on? It is only like
Could be a fuse in the unit or a bad powersupply i would have a estimate done on it before repair gets started as a newer tv would cost less if this was a major issue.
1. check fuse
2. check power supply unit
If you do not know how to do this would recommend you take it to the experts as there is serious high voltage that can be fatal inside, Please do leave postive feedback and ratings for your free answer today.
