Question about HP PSC 1315 All-In-One InkJet Printer
My HP PSC 1315 printer isn't printing. Whenever I attempt to print something, the roller takes the paper in halfway and then stops. The "Check Paper" and "Check Print Cartridge" start flashing.
  • Anonymous Dec 01, 2008
    The problem started when I had a paper jam. After that, the printer always takes a half sheet of paper and then acts like another paper jam. I can only use the printer if I don't load any paper, then send my document, then wait for the printer to tell me that it is out of paper and clear that error. Then put one sheet of paper in and let it print out.
  • Anonymous Dec 16, 2008
    I also have the same problem. When I try to print, the paper goes halfway and stops. Both the paper jam and inkjet lights start flashing. I cleaned the rollers like it said on the HP site and checked for and obstructions, but nothing seems to be out of place or in the way.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Printer will not power up!
Posted on Dec 15, 2008
My hp 1315 check paper is blinking
un clip the back door there might b a jam of paper that u cant see but printer can detect once u have done that u must !! pres enter 2 reset it after u have replaced the rear door of course
Sep 28, 2012 | HP PSC 1315 All-In-One InkJet Printer
Printer will not print.a photo paper went thru on a angle. now it will not print.
A paper jamb could be caused by dirty orsticky rollers, also failure to remove all traces of paper from a previouspaper jamb.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.
Try cleaning the rollers with methylated spirits
May 28, 2011 | HP PSC 1315 All-In-One InkJet Printer
Will not print. says out of paper but there is paper in the tray.
this is indicate that the roller is having some kind of problem.
open the backdoor, make sure there is nothing preventing the roller (should be 3) do its job.
take out the paper from the paper tray. make sure there nothing in the way of center roller path.
re position the paper. load enough paper, so that the paper is right under neath the center roller, remove 2 sheet. try to print. if it pickup the paper, then it is telling you that the roller need to be replaced. if it still having problem pickup the paper. then there is something else we need to investigate.
Hp always being having problem with their printer roller since day one. over time the roller become smooth, and not able to pick up paper.
if the porblem presist, please repost it in this thread. so I can help you to solve the problem.
Nov 13, 2008 | HP PSC 1315 All-In-One InkJet Printer
Trouble shooting my printer all in one 1315 series
You need to clean the rollers in the back panel of the printer.
Unplug the printer while it is powered on and remove the back panel. Get a damp cloth (not too wet) and wipe off the rubber rollers in the printer as well as on the panel. Replace the panel and plug printer back in. It should come on by itself and initialize.
Print a page from your computer. It should now only feed a single sheet at a time.
Jul 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
my printer no function cant print
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer jam
open top cover of your printer and put a couple of drops of 3 in 1 oil on the carrige bar ( THE BIG SILVER BAR THE INK CARTRIDGES RIDE ON)
THEN CLEAN ALL THE RUBBER FEED ROLLERS WITH A MICROFIBER TOWEL MOISTENED WITH ISOPROPANOL ALCOHOL THEN TRY THE PRINTER AGAIN
Jan 11, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP psc 1315 all in one-printing cards
Make sure you check the settings in the print driver. Sounds like your paper size settings do not match the size of the paper that you are printing onto and you are actually getting a false jam because the machine is seeing a different size paper then you ahve in it.
Dec 18, 2007 | HP PSC 1315 All-In-One InkJet Printer
Unable to print
The problems is not the cd for installed and my printer psc 1315 no instaled. Because the computer is repared.
Dec 21, 2006 | HP PSC 1315 All-in-One Printer
HP PSC 1315 All-In-One InkJet Printer Logo
257 people viewed this question
Ben Johnson
