Question about Kitchen Ranges
Oven door locked, F9 indicator signal
The power went off at my house - when it came back on the oven door was locked and showing an F9 message. Any ideas ? Jenn-Air Double Oven Freestanding Range, lower oven lock will not release after cleaning. Flashing lock light in cool down mode. Tommorow is Thanksgiving. HELP !
  • scoreski_k8 Jan 14, 2009
    i have a jenn air gas range oven. i leaned into the oven and apparently hit some buttons on the control panel. repetitious loud clicking occurred and when it finally stopped, the oven door was locked. The oven will only show an F9 signal. ive tried clicking buttons, but nothing seems to be working.. How do i unlock it?!
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
F9 has to do with the door lock/latch monitoring switch, i would try to remove the oven for mthe counter andremove the back panel, in the approximate hieght levle of hte top of the lower oven mounted to the right side( standing behind) unit youll find a small lacth / motor assy, that drivesthe self clean latch, WITH POWER TURNED OFF> i wouldlook closely at the switch mounted to the assembly make sure its not out of line , (perhaps twiste doff to the side, not making contact, or something else real obvious.. definalty related ti a faulty read of that switch .chances are it got 2 hot and distortred teh mounting and/or function of that part.. worth a try any way good luck!
Posted on Nov 27, 2008
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 05, 2013 | Ovens
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
Feb 07, 2011 | Maytag Ovens
Get message F9 on the display, I went to clean the oven in the self cleaning mode, heard the door latch trying to close, then it started beeping and flashing the F9 on the display. I turned off power for...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 17, 2010 | Kenmore 95592 / 95594 / 95595 / 95599...
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas range will not stop beeping showing F9 in window
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%^
Apr 03, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Monster, F9 is the door locked error. Try turning off the breaker for 30 seconds and see if it resets. If not, you are going to have to get a coat hanger, make a U at one end and slip it between the door and latch from the left. Once you feel the latch, give it a tug and the door should open. Try resetting the board again with the door open and see if the lock mechanism homes. If not you will have to check the cam and switches for problems. Catriver..post back.
Oct 05, 2006 | Jenn-Air JER8855 Electric Kitchen Range
Kitchen Ranges Logo
393 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
