Question about Sharp Notevision PG-B10S Multimedia Projector
Dead will not power on, dead as a hammer!the fuse is good.
  • gholt12345 May 11, 2010
    where is thermistor near lamp button or lamp
    Problem Solver:
  • 14 Answers
CHECK THE THERMISTOR NEAR THE LAMP AND RESET BY PRESSING IT.
Posted on Jun 04, 2007
SOURCE:
My 2002 Jetta TDI wont Crank
Check fuses first. Crank/start fuse. IF that's good. Find the starter and hit it with a hammer or rod/pry bar as some one tries to start it. If it starts, replace the starter. It has a dead spot in it. If it doesn't, try jumping the small wire to the big wire. It will arc, but if it doesn't turn replace the starter. If it does turn, check the small wire for power when turning the key to start. No power, go to the crank fuse and check for power when trying to start, still no power. Then it is a break in the wire from there to the ignition switch. Or the ignition switch is bad.
Oct 08, 2016 | 2002 Volkswagen Jetta TDI
Tip
How to bring a dead battery back to life
Do we give up on people as soon as they stop breathing? No, we give them CPR. So why do we give up so quickly on our batteries.
Here's a little trick I learned while camping in the Philippines when my flashlight went dead. Works every time
Instructions Things You'll Need:
  • Hammer or Rock or other device that can be used as a hammer
  1. Step 1 Remove the tired battery from the appliance and place it outside on the ground. Do not remove batteries that have leaked acid.
  2. Step 2 Take your hammer or rock or other hammer-like device and give it a good whack right in the middle of the battery -enough to make a small dent. Be careful of your hands while executing this step. You could put the battery inside a clear plastic bag to give you more control.
  3. Step 3going a little longer It will work usually a few more days-weeks depending on the demand required from it. Enough time for you to buy more batteries. If it doesn't provide more power after one whack, give it another 1-2 whacks.
on Dec 26, 2009 | Duracell AAA NiMH Battery Charger with 4...
2004 f150 radio dead
i think u should have a main fuse box under the hood... i don't know a lot about f150s.. But check that also....
Feb 03, 2014 | Cars & Trucks
05 deville no start turn key on dose nothing
hello Allen. Deville leaks in to my Toyota, forum section, oddly?
but
Engine size not stated.
nor if it cranks robustly
if key is dead, and dash dead, and or head lights dead
check all fuses first in the cab and in the engine bay.
always check fuses first. the battery voltage.
bam 10v bad battery ,dead, or discharged, (i charge it and ./...???)_
battery is good and jumper starts fail.
you turn the key to on, the check engine light glows, (and othere)
that is something
then you move key to crank position (start) i will wiggle the shiftlever.
boom is cranks
no it dont so i try starting in neutral. bam , it cranks. over. bad PRNDL switch.
no it dont, so i hit the starter with a hammer, not crazy just tap tap.
no it dont start.
I hot wire the starter solenoid. it cranks (wont start , key in pockets)
hot wire fails,battery good, starter is toast.
hot wire test passes ,cranks nice.
i then grab my trusty DMM and flip dial to Volts.
i then find why my KEY line is dead.
if you get this far, ask how to fix a dead Key line.,
the starter ST key line,
Dec 12, 2013 | Vehicle Parts & Accessories
NO taillites, no brake lites, no door locks, no power to windows, no ability to move "Park" lever and all small fuses in fuse box are good
sound like dead battery or corroded cables.check see if battery has 12.5 volts.if not battery dead.
Dec 28, 2012 | 2002 Lexus RX 300
Dead Fan blower 2006 Kia Sportage has 12v power, should I replace it?
Could be your blower motor resistor,it's mounted next to the blower motor,Autozone will take part back for refund if it don't fix problem.Here's what it looks like,Here's where the blower motor is.Easy to remove,disconnect electrical connector,remove 2 screws,can't look at it to tell if bad.Here's the relay.
Dec 23, 2012 | 2006 Kia Sportage
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
Heater fan not working
check for power at fan, but frist check all fuses. if fuses are good then check for power at fan if you have power at fan then fan is bad.hope this helps.
Oct 08, 2009 | 2000 Pontiac Grand Prix
Power light on amp will not come on
the brushes need to be checked,
or the cord.
Mar 09, 2009 | Hitachi Rotary Hammer Kit 15/16,SDS, 0...
Sharp Notevision PG-B10S Multimedia Projector Logo
205 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
