GPS Logo
Posted on Nov 27, 2008
How to secure on dashboard? Adhesive disk has only one side has adhesive.
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 28, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
1203
Points
14
Secure to dash with adhesive side. other side fits into holder.
Lost adhesive hook for Tom Tom dashboard mount
take a 2 sided tape and fix the tom tom dash mount.. it will temporarily solve your problem... then later u can buy a new one
I own an acer 10.1"
it isnt that difficult actually , a how to for removing the lcd is shown here
Remove the four screw caps and screws from the LCD Bezel.
NOTE: The two center screw caps at the top of the bezel are for protection only.
Starting from the inside top edge, pry the bezel away from the panel. Continue moving down the sides until the bezel is removed. If necessary, use a plastic pry to release the corners of the bezel.
1063_66_97.jpg 4. Lift up the bezel and remove it from the LCD Module.
IMPORTANT: If the LCD Bezel is replaced, remove the lid sensor magnet from the bezel, and attach it to the replacement bezel.
  1. Disconnect the cable from the Camera Board as shown.
1063_66_99.jpg Remove the Camera Board from the LCD Module.
  1. Remove the four securing screws (two each side) from the LCD Panel brackets.
1063_66_104.jpg Turn the LCD panel over on a clean surface. Remove the adhesive strips securing the LCD cable.Carefully lift the adhesive tape securing the cable connector to the LCD Panel.
1063_66_105.jpg 5. Hold the adhesive tape clear of the LCD Panel and disconnect the LCD cable as shown.
  1. Remove the adhesive strips holding the MIC cable in place.
1063_66_107.jpg 3. Remove the MIC Board from the LCD Module.
  1. Remove the adhesive strips holding the Camera cable in place.
  2. Remove the Camera cable from the LCD Module.
  1. Remove the adhesive strips holding the Antenna cables in place.
1063_66_110.jpgCarefully pry up the Antenna pads, as shown, and remove the pads from the LCD Module. IMPORTANT: A strong adhesive is used to secure the Antenna pads in place. Take care not to bend the pads during removal.
to fit a new one do the steps in reverse
If you found this info useful Please vote for me
Sandpaper will not stick to pad
Use a quality adhesive backed sanding disk, and clean the pad area with isopropanol/alcohol. This should allow the adhesive disk to stick.
I recommend 3M adhesive disks.
1helpful
Sand paper keeps slipping help
I don't know what type of sander you are speaking about it just says generic ALL PORTER CABLE SANDERS. You got to be a little more specific. If it is a disk sander use 3M disk adhesive. It is a contact cement. spread some on the rubber backing disk with your hand, let dry then apply the sanding disk. After the disk is clogged, peel it off and apply another disk. when the adhesive won't hold anymore disks, re-apply the adhesive.
2helpful
2answers
Install luan over concretehow to secure plywood screws or glue?
You are much better off using an adhesive rather than screws. Home depot sells several good flooring adhesives, usually in aisle 8 that will do the trick just fine
I just bought the magellan maestro, and I can't get the suction cup to stick. The surface is clean and we wet it, but it loosens rapidly.
The GPS unit comes with an adhesive disk that must be installed on the surface where you want to place the GPS unit. The suction cup will only work with this adhesive disk. Once the adhesive disk is installed, the suction cup will hold. Here's the instructions magellan web site...
  1. Clean and dry the dashboard where the adhesive disk is going to be installed using enclosed alcohol pad.
  2. Remove the protective paper cover from the bottom of the adhesive disk; place the bottom of the adhesive disk firmly on the dashboard.
  3. Apply even pressure on the top of the adhesive disk for a secure fit (Allow 24 hours to cure).
  4. Place suction cup mount on top of adhesive disk.
  5. Firmly press suction cup mount down flat against the adhesive disk, press the suction cup lever down to secure the suction cup to the adhesive disk.
2answers
Dash board mount
you can buy a heavy duty double adhesive tape, or use a permanent adhesive, or mighty bond onto your dash board since the gps is still removable
I recently got a new car and had to transport my GPS to my my new car. Problem is the mount that you put on the dash will no longer stick to it. How do I fix this problem?
Hello Hoshiko,
You don't say what kind of mount you are using. There are a couple different kind. One kind uses an adhesive (like double sided sticky tape) to secure the mount to the dashboard. For this kind of mount you can simply purchase some new adhesive tape to apply. This is available from most hardware or electronics stores.
The second type of mount uses a suction cup type device to secure the GPS to the dashboard. For this type you will want to make sure you are attaching the mount to a smooth, nonporous surface. Make sure that the area you are attempting to afix the suction cup to is clean and dry. Make sure that the suction cup itself is clean and moisten it with just a little bit of water before attempting to get the mount to stick.
If you still can't get the mount to stick to the dashboard you might need to look at other mounting options or purchase a replacement mount.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 24, 2008 • GPS
350 disk
The adhesive disk is for attaching to a dashboard, not a windshield.  The unit is supplied with a suction cup for use on a windshield.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
